02-27-2010, 04:12 PM
Member #3370
Steering Problem
I have a 02' Sportsman 500 4x4. Sometimes while I'm driving it will jerk to the left especially when i hit a small bump. Other times the steering will just kinda lock up so I can't turn it left and I have to shake the bars to free it up. When it does jerk it sometimes makes kind of a pop sound and I can hear a little bit of a rattle under the front when it starts doing this. What problems or parts could be causing this problem?
02-27-2010, 04:17 PM
02-27-2010, 04:29 PM
possibly the bushings on the steering shaft are bad
02-27-2010, 04:39 PM
Member #2920
Sounds like something is binding up with your steering.
Looks like you need to stand her up and start inspecting all steering components. Work it back and forth left/right and check for proper lubrication, bearings, bushings, and bent tie rods.
You definatly don't want it locking up on you on the trails.
02-27-2010, 04:55 PM
Member #3370
Thanks guys, does this stuff sound like an expensive problem or are these parts generally not too bad?
02-27-2010, 05:03 PM
bushings = cheap
bearing = affordable
tie rods = expensive.
hard to tell at this point
02-28-2010, 04:34 AM
Member #1234
check cv boots &cv joints
02-28-2010, 05:00 AM
Member #1414
i would stop riding the quad till you check it out or have it checked. there was a young teen killed near me when a worn tie rod came apart and the quad flipped on top of him.the sheriff was not real happy with the parents for letting the teen ride a unsafe quad.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
02-28-2010, 12:07 PM
Member #2920
Agree. Don't ride it until you figure it out.
1999 polaris ranger steering, 1999 polaris sportsman 500 steering, 1999 sportsman 500 steering bushing, 2003 polaris sportsman steering post, how do you install a steering shaft sleeve on a polaris sportsman 90, polaris 350 l steering stem bushings, polaris 4x4 steering problems, polaris ranger power steering quit, polaris ranger steering bushings, polaris ranger steering problem, polaris ranger steering problems, polaris ranger steering shaft problems, polaris sportsman 335 steering problem, polaris sportsman 500 steering problems, polaris sportsman steering bushing, polaris sportsman steering problem, ranger polaris 500 steering lock, replacing brakes1999 polaris sportsman 335 4x4, steering problem polaris ranger 2010, you tubepower steering install on polaris 1999 polaris sportsman 500
