Old 03-01-2010, 06:15 AM
fishdoktor's Avatar
Member #3314
Question 1994 400 Sportsman water in counterbalancer.
Is there any other way for water to get into the counterbalancer other than the water pump? I have disconnected the internal water pump and am running a 12 volt external pump but I'm still getting water in the balancer. Also I have no dipstick on the back of the engine case to check it. Been using the front plug right below the the water pump housing. The hole is there looks like it is filled with some black stuff. No way to get it out. Could the previous owner have broken it off? Were they black in color? Thanks for any help.
Old 03-01-2010, 09:52 AM
4getful2's Avatar
Member #1234
the oem counterbalance dipsticks were an aluminum knurled screw-in piece. i don't see how it could've gotten broken,(lost? or fell out, maybe) then rtv'd the fill hole ,then forgot about it.
I don't know that you can completely bypass the water pump area that you are talking about.
1994 polaris 400 atv water pump
1994 polaris 400 counter balancer oil level
1994 polaris 400 counter ballencer
1994 polaris 400 water pump
1994 polaris sporsman water pump veiw
1994 polaris sportsman water pump
94 polaris 400l water in counterbalance housing
94 polaris oil dipstick
balancer 400 sportsman
bypass water pump on polaris sportsman
counter balancer noise polaris sportsman 1994
how to pull the water pump bearing on a 400 sportsman
polaris 400 counterbalancer
polaris 400 engine balancer
polaris 400cc water pump bearing
polaris 400l 1994 milky counter balance
polaris 400l 1994 oil dipstick broke
polaris 400l 4x4 1994 counterbalance
polaris 400l counterbalance dipstick broke
polaris sportsman high flow water pump
1994 Sportsman Maintenance and Repair Questions toshi38toshi38 Polaris Sportsman 5 03-25-2010 05:54 PM
No power after heavy water ridin Jarbo11 Polaris Sportsman 4 09-23-2009 04:07 AM
Ridding in water Fred j 500 ATV New Members 3 06-22-2009 10:17 AM
polaris 500 water pump jpringle ATV General Discussion 2 06-21-2009 05:22 PM
high flow water pumps for sportsman 800 joshhhoff ATV Performance Modifications 1 05-26-2009 06:48 PM
