1997 Xplorer will not shift - Polaris ATV Forum
post #1 of 11 (permalink) Old 09-06-2012, 02:23 PM Thread Starter
Billycalexander's Avatar
I have a 1997 Xplorer 500 that has been getting hard to shift from forward to reverse or reverse to forward no matter if it was running or not. Now it will not shift at all. I searched but couldn't find this particular problem discussed on any thread. Anyone got any ideas, hopefully there's an adjustment in one of the shift linkages that will fix it???
Thanks in advance
Billy Alexander
Billycalexander is offline
post #2 of 11 (permalink) Old 09-07-2012, 06:30 AM
tt425's Avatar
The problem more than likely will be the shift linkage. It can be adjusted. It has to be set just right. The rod end at the shifter will be left hand thread. Disconnect the rods from the shifter. I think it is hung up in 2 gears low and reverse. The long rod that connects to the rear bell crank is for HI and Reverse. The rod moves forward for reverse and back for HI. The front bell crank is for low gear. It moves forward to engage in LOW gear. Work the rods manualy while rolling the atv back and forth to get it disengaged out of both gears. I hope this will help you.
tt425 is offline
post #3 of 11 (permalink) Old 09-07-2012, 07:09 AM Thread Starter
thanks tt425, I'll work on it today and let you know how it turns out!
Billy
post #4 of 11 (permalink) Old 09-07-2012, 09:47 AM
tt425's Avatar
Ok. No problem
tt425 is offline
post #5 of 11 (permalink) Old 09-07-2012, 02:29 PM
InRBigness's Avatar
the shift lever itself is a poor design and the pin that the rods connect to at the lever wears out in its housing. Also check to make sure that the Bell crank is not cracked.
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #6 of 11 (permalink) Old 09-10-2012, 09:17 AM Thread Starter
I took the two shift rods off the shifter box and it made no difference in the ability to shift. I was actually able to shift it some this weekend but not now. Since the problem remained with the rods disconnected, I guess I'll be tearing into the shifter box? Also it has electrical wires coming from it, are they just indicator wires for forward and reverse and neutral, or some type of lockout/safety feature that might be malfunctioning?
Billy
post #7 of 11 (permalink) Old 09-10-2012, 09:50 AM
tt425's Avatar
If it made no difference with the rods disconnected that means you have a problem with the transmission.
tt425 is offline
post #8 of 11 (permalink) Old 09-10-2012, 05:08 PM Thread Starter
I disconnected them from the shifter box so with the shifter box disconnected it(the shift knob)still would not move. the rods would work the transmission easily just with me pushing them by hand.
post #9 of 11 (permalink) Old 09-10-2012, 06:13 PM
InRBigness's Avatar
you need a new shift lever. You really cant fix what is broken. Once you take it apart you will see why.
08 Sportsman 500HO
post #10 of 11 (permalink) Old 09-12-2012, 10:10 AM Thread Starter
Good news
the boot had a hole in it and there was water and muck all in the shifter box with literally no oil. I took it all apart except I couldnt find the stop pin, it works fine now but not sure yet if the electrical indicator switch is shot or not, i put it back on the bike without the electrical loom/switch and it runs/shifts fine so I guess there is no lockout just an indicator function. So is motor oil or gear oil better, it really didn't seem to matter as its not a rapidly moving system.
billy
1997 Polaris xplorer focushunter ATV General Discussion 24 03-31-2017 05:15 PM
1997 xplorer 500 advise Lennartchurch Polaris Sportsman 0 01-31-2012 06:00 PM
Xplorer gear shift box fluid questions mac67 ATV Repair and Maintenance 6 10-03-2011 12:00 PM
1997 Xplorer 500 Burghfan913 ATV New Members 1 08-21-2011 05:49 PM
1997 Xplorer 400 4X4 exhaust tasertotts ATV Performance Modifications 3 12-16-2010 03:49 PM
