electrical problems - Polaris ATV Forum
post #1 of 6 (permalink) Old 10-16-2012, 09:06 AM Thread Starter
tvolsr1's Avatar
electrical problems
2008 sportsman 500 carburated. My son decided to use it as a submarine a few weeks ago. I drained fluids and started it, no problems. After setting for a few days it will no longer start, won't even turn over. I have replaced battery (it was weak anyways), checked the starter solenoid (good), and checked ground and wiring and it's all good. I've got a clymer service manual and it says that 08 models have a circuit breaker and fuse panel. Can anyone tell me where they are located??? I've looked under the headlight and there are only two boxes. One is the ECU and the other is a solid black box. Also, the speedo assembly has water in it and the digital readout is not working. Could the speedo assembly be my problem? ANY help is greatly appreciated.
tvolsr1 is offline
post #2 of 6 (permalink) Old 10-16-2012, 11:38 AM
InRBigness's Avatar
I would try and hook the starter up directly to a known good battery. I will bet that some water got in the starter and the brushes are rusted and not making contact. If it does move on to the next suggestion.
If that turns over then you have other issues. One thing the speedo does is tells the quad what gear it is in. If you are not in neutral or park you have to pull the hand brake to start. If that is not working right you may have found a problem.
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #3 of 6 (permalink) Old 10-16-2012, 04:19 PM
Bruce! is offline
post #4 of 6 (permalink) Old 10-20-2012, 10:56 AM Thread Starter
tvolsr1's Avatar
PROBLEM SOLVED!!!!! I bought a new speedometer for it and it fired right up.
tvolsr1 is offline
post #5 of 6 (permalink) Old 10-20-2012, 11:01 AM
vortecz71wv's Avatar
Sorry man , wish i would have seen this sooner so you could have been up and running. Had this happen to a 2001 sportsman and a new speedo fixed it.
Matt
Mine:
2011 Sportsman 800
Polaris Front Brush Guard, Polaris Rear Brush Guard, Polaris Rear Rack Extender, Polaris L&R Rear Cargo Box, Warn 2500lb winch, Winch Saver, Ricochet A-Arm Guards (www.TheATVSuperStore.com), 3-High Headlight Mod, 6000k HID kit, Rigid Ind. 2xDually w/ strobe box, UNI Air Filter, 26" GBC Dirt Commanders, 1" Billet Wheel Spacers (Front and Rear) HighLifter HD springs, Dalton Primary Spring O\BL, Realtree Seat custom cover, Polaris Handguards
Wife's
2011 Sportsman 550XP
Polaris Front Brush Guard, Polaris Rear Brush Guards, Polaris Rear Rack Extender, 26" GBC Grim Reapers, Viper Elite 3000lbs Winch w/ wireless, Polaris Handguards, 6000k HID Kit
Fuel It, Flog It, Feel It!
vortecz71wv is offline
post #6 of 6 (permalink) Old 10-22-2012, 07:27 AM Thread Starter
tvolsr1's Avatar
We rode it all weekend and it did fine. So speedo was difinitely the problem. Even though $250 for the speedo wasn't cheap, I'm glad I took a guess instead of taking to the polaris dealer for $75 an hour!
tvolsr1 is offline
electrical problems Toomanycars Polaris Scrambler 2 10-27-2014 09:27 AM
Electrical Problems 600RacerX Polaris Sportsman 4 05-30-2012 11:14 AM
electrical problems kristi00 ATV General Discussion 1 04-01-2012 04:17 PM
Electrical problems...help please 2001polarissportsman90 ATV Repair and Maintenance 3 07-04-2011 04:25 PM
electrical problems robster248 ATV Repair and Maintenance 17 05-17-2011 05:31 PM
