2004 Polaris Sportsman 700 EFI Won't start... - Polaris ATV Forum
post #1 of 11 (permalink) Old 10-16-2012, 06:48 PM Thread Starter
Flipmode22's Avatar
Went to get on my bike today to ride around the yard with my son, turned the key and "Click". Tried it again, and "Click". Took the seat off to try to hear where the click was coming from and it seemed like it was coming from the battery, but the battery has a full charge. Could this be the starter? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!! I need my bike for when the snow flies to plow the driveway...
Thank you in advance for the help!
Flipmode22 is offline
post #2 of 11 (permalink) Old 10-16-2012, 06:54 PM
Clinebo's Avatar
How do your connections look? Any corrosion or loose nuts? Check the ground cable and make sure you are getting a good ground.
2002 Sportsman 500 HO
Warn 25XT + Bumper
25" Grim Reapers
GoldFinger left hand throttle
and other stuff...
Clinebo is offline
post #3 of 11 (permalink) Old 10-16-2012, 06:58 PM Thread Starter
Flipmode22's Avatar
I will check them tomorrow. I checked the connections to the battery, and the black box, and they all seemed to be tight and looked ok. I was riding it around the yard yesterday, and now today it just clicks. BOOOO!!!!!!!!!!
post #4 of 11 (permalink) Old 10-17-2012, 05:54 AM
bgirard420's Avatar
Have you tried jumping the solenoid?
Rather be riding, instead I'm using Tapatalk
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
bgirard420 is offline
post #5 of 11 (permalink) Old 10-18-2012, 04:35 AM
gmiller0737's Avatar
Might want to put a volt meter on the battery Fully charged would be around 12.6 volts,Look & see what the voltmeter does when you try & start it,Or take battery out & have it tested.
gmiller0737 is offline
post #6 of 11 (permalink) Old 10-18-2012, 04:58 AM
KICKER431's Avatar
I had this same problem on my 2004 EFI a couple of weeks ago. Here is what I tried and figured out.
My battery had been on a battery tender for a couple of months while i was away on work. I got back and I got the same thing. Pod lit up, key turned, click, nothign from the engine.
1. Put a battery charger on the battery. It read fully charged immediately so either the battery really is charged or it isn't going to take a charge.
2. Checked the battery connections. They looked clean but I took them off and cleaned them with a wire brush and some coke anyway. Put them back on. Stiill just a click.
3. Tried jumping it with my wife's ATV and my Dodge. Neither got me more than a click. So at this point I am almost positive the battery isn't the problem. If it was I should have been able to jump it.
4. Try tapping the starter with a hammer while turning the key. If the starter is beginning to go bad this should break it loose and get it started spinning. Didn't work for me. This doesn't confirm the starter is bad. If it had started turning then I would have known. Instead this test didn't help at all.
5. Pulled the air box so I could get directly to the starter. I put the jumper cab;es from the battery to the starter, bypassing the solenoid. I can hear the starter drawing power but it still doesn't turn.
6. So at htis point I know my battery and my solenoid isn't the problem. Either the starter is bad or the whole engine is frozen. Doing some reading I found starters to be a not uncommon problem. So I pulled the starter out (thankfully a ver easy job on our model compared to some others.) I hokked the jumper cables directly to the starter and it didn't turn, but if I hit it with a hammer while hooked up it would turn about 1/8 of a revolution. So there we go, my starter is frozen.
I opened up the starter to look at it. it looked like a toxic waste site with corrosion and mud. so I ordered a new one on ebay from DBELECTRICAL. Mirrors, Starters Tractor items in DB Electrical-Starters-Alternators store on eBay! It arrived in about 3 days and took 15 minutes to put in. Back in business.
I hope my experience helps you to figure out your issue.
completely stock FOR NOW
26" Maxxis Bighorn 2.0
KICKER431 is offline
post #7 of 11 (permalink) Old 10-20-2012, 09:55 AM Thread Starter
Flipmode22's Avatar
I took the battery connection off of the starter/solenoid (is this the same thing?), cleaned the ends, and I went to screw everything back together and I over tightened the nut and the plastic piece cracked in half. Good new is that it started after that, bad news is that I now have to buy a new starter. NO GOOD!
My question is should I buy the solenoid and the starter? Is it all one piece, or does the solenoid fit into the starter? I may just try to look up the parts list online so that I know what the heck I'm even talking about. I hate not knowing what im doing...
Thanks for the help guys, I honestly wouldn't have enen known where to begin without you!
post #8 of 11 (permalink) Old 10-20-2012, 09:59 AM Thread Starter
Flipmode22's Avatar
After looking at the picture it's the solenoid that I cracked...
post #9 of 11 (permalink) Old 10-20-2012, 10:03 AM Thread Starter
Flipmode22's Avatar
My bike is a 2004 Sportsman 700 EFI, do I have to buy a solenoid that says it's for an EFI, or can I buy any one from 2004 for a 700?
post #10 of 11 (permalink) Old 10-20-2012, 12:19 PM
KICKER431's Avatar
Here is a hint for parts quandries. You can find factory parts diagrams on a lot of websites. Often it is places selling parts that just post the factory diagrams for people to identify the parts numbers that they want. I use cheapcycleparts.com.
So Ilooked up a 2004 700 EFi parts diagram and a 2004 carbuerated diagram for you.
EFI ELECTRICAL/TAILLIGHT - A04CH68AP/AQ/AU/CU Polaris Sportsman 700 (A04CH68AP/AQ/AU/CU) 2004 OEM Parts - Cheap Cycle Parts
Carbuerated ELECTRICAL/TAILLIGHT - A04CH68AC/AF/AH/AJ/AT/AV Polaris Sportsman 700 (A04CH68AC/AF/AH/AJ/AT/AV) 2004 OEM Parts - Cheap Cycle Parts
The both list the Solenoid (or magnetic switch as they call it) as #20 in the diagrams and Part number 4011335. So they are indeed the same part.
Again, I hope that helps. I look up parts all the time, especially to see if parts I have for my '04 are the same as parts for my '07 and vice-versa.
2004 Polaris Trail boss 330 no start Bensmotorworks ATV Repair and Maintenance 5 04-18-2012 01:28 PM
2004 Sportsman 600 start problems PolarisWes Polaris Sportsman 5 01-12-2011 06:03 PM
2004 Polaris Sportsman 500 HO Hard to Start in Cold Brent309 Polaris Sportsman 4 12-13-2010 12:24 PM
2004 Polaris Sportsman 600 wont start PolarisWes ATV Repair and Maintenance 10 10-26-2010 09:32 AM
2004 Sportsman 700 won's start cetinkaya ATV Repair and Maintenance 1 07-30-2010 03:29 PM
