Old 03-12-2010, 05:27 AM
bowhunter's Avatar
Member #3601
01 sportsman 90 cutting out
You guys are probably sick of answering this question, sorry! Just bought an old S90 for my youngest son. Went thru the carb, all new gas lines. It cuts out when you give it some throttle, not all the time. It seems to get better when warmed up. But still erratic on the running thing. It just shuts off and then is fine when ya let off the throttle. It will idle all day, but just attept to give it gas. Sometimes just off of idle, sometimes at half throttle. Any ideas???
Old 03-12-2010, 07:13 AM
Old 03-12-2010, 09:33 AM
this is a 2-stroke right?
my first thought right off the bat is the spark plug is on its last leg. especially on a 2-stroke, they can foul quick. a fouled spark plug will let an engine idle pretty good, but whill choke out and die when you give it gas.
a new spark plug should be like $3 and quick to do to see if it helps or not
Old 03-12-2010, 09:51 AM
bowhunter's Avatar
Member #3601
I've been a mechanic for almost 27 years. Working on autos, boats, four wheelers, you name it. Never seen a plug react that way. I actually changed it out just before you replied. Guess what, problem solved. Thanks guys!!! I will be back again. I am usually on an archery forum, but, always looking for ways I can help others, and ones that can help me.
Old 03-12-2010, 10:16 AM
those little 2-strokes are tricky guys. glad you got it fixed
Old 03-19-2010, 11:24 AM
bowhunter's Avatar
Member #3601
Thought I had it fixed. Ready to pull the last hair out of my head! Son took it out, and after 10-15 minutes of riding, it does the same thing. Put in new plug, same thing! Done tearing my hair out. Took it to a real small engine mech. and he has had it sitting there all week, hasn't touched it yet. Gonna go pick it up. When it cuts out, it has spark. I put a timing light on it just to see if it was the spark cutting. Seems to be gas related, but everything is absolutely spotless, and when I pull the gas line, it flows plenty good. It has plenty of power, so compression should be fine. Little sucker will pull the front wheels off the ground with 195 lbs on it, me.
Old 03-22-2010, 12:28 PM
bowhunter's Avatar
Member #3601
FOUND IT!!! I get a little retarded when I work on little 2 strokes. Should have thought of it before. COIL!!!
Old 03-22-2010, 12:32 PM
good deal man! hopefully the germlin that was living in that machine is gone
2004 polaris sportsman 90 stall out
4 wheeler dies when i give it gas
4 wheeler sat for year cranks but bogs when given gas
atv dies when i give it gas
atv forum 2 stroke dies when i give it gas
polaris 90 cuts out
polaris 90 cutting off
polaris 90 cutting out
polaris 90 dies at half throttle
polaris 90 dies when i turn
polaris sportsman 90 bogs down
polaris sportsman 90 dies
polaris sportsman 90 dies when choke
polaris sportsman 90 stalls
why every time i press the throttle on my quad it cuts out
01 325 trailboss cutting out!!!! keith24k ATV Repair and Maintenance 13 10-23-2012 03:46 PM
96 Sportsman 500 cutting out under load harliqu1n ATV Repair and Maintenance 5 05-24-2012 01:46 PM
