03-14-2010, 12:23 PM
Member #3465
08 Sportsman winch mounting
Did anyone manage to get the original cover back on after mounting a winch? Is there a template to use to cut it out or will it even fit anymore with the winch installed?
03-14-2010, 12:36 PM
there is no templete to cut the orginal panel, and its not really worth it because it is a pain in the ass to make it look good. but luckily, polaris makes and sells a front cover that already has a hole cut out for the winch. honestly, the dealer should have put one on for you when they were done. but still you can order the cover from any dealer. it is PN# 5436991-070 and is $9.43. for less then $10, its worth saving the headache of trying to cut your orginal. the new cover though wont come with the blue polaris star decal, so you will need to try to find the orginal one if the dealer has it, and with a flathead screwdriver, you can peal the blue star decal off of the orginal one and put it on the new one with the winch cut out.
this is the panel i am talking about. already pre cut. only the winch fairleads stick out.
03-14-2010, 06:04 PM
Member #206
yes there is actualy a template. but i got mine when i got the mount from kfi. they had about 6 templates with it. and if i would have gotten the polaris oem cut out it wouldnt have worked as mine was centerd in the opening and the plate was cut out in the center. if your winch sits in the center i maybe able to scan it and send it to ya via email. or i could scan them all and send them to ya. the winces that polaris sells or the mounts looks like the off center. but heres mine. i cut mine out. did a good job to.
2008 polaris sportsman 500ho carb (cash paid)
home made 54" snow plow
3000lb warn winch
6 911ep led warning lights and a ls12
LED taillights & work lights
K&N air filter
P-X-T tires and alum rims
hand/thumb warmers
also have:
fimco boom sprayer with lock and ride mounts made by me
pull behind grader and box scraper
just added the rotopax gas packs to the front of my wheeler
03-15-2010, 01:02 PM
Member #2883
I cut mine myself like "Chuckradunez" It actually came out pretty good. I cut it with a jig saw. It also allows you to cut it big enough so you can use the "free spool" option of the winch. It looks like the pre-cut one won't give you enought room to get to to the free spool lever. Just my two cents!!
 2009 Sportsman 500 EFI (Red)
03-15-2010, 03:30 PM
Member #3465
Ya those look pretty nice, I think I might try and get mine to work. I definatly need to access the free spool latch. I have to look at my install. I thought mine was over to one side rather than in the middle.
03-15-2010, 05:06 PM
it does. there is enough room to slide your fingers in and flip the free spool lever up or down
03-26-2010, 03:16 PM
Member #2912
Thanks blueline15 for that part#. Got mine today from my dealer.......$10.
03-26-2010, 03:46 PM
Member #3465
I dont know why those dicks didnt sell me one of those when I bought y quad. Bunch or muther fuggers.
2009 800 Touring Warn winch, Garmin Oregon 300, Elka Elite rears, Moose hand and thumb warmer, sport windshield, Glacier 2 plow system, Sears Poulan Pro 18" chainsaw, meep meep horn, looking for some nice mirrors. HID kit ripped off by ATV Superstore
2010 polaris sportsman 500 winch mount, atvs climbing, how to install a winch to a polaris atv, install winch on 2008 polaris sportsman 500, pictures of winches on polaris sportsman, polaris 335 winch mount plate, polaris atv winch, polaris forum sportsman oem winch, polaris sportsman center mount winch, polaris sportsman winch, polaris sportsman winch installation, polaris sportsman winch mount, polaris sportsman with winch, polaris sportsman with winch images, polaris winch cut out, polaris winch cut out panel, sportsman winch mount, winch on polaris sportsman, winch plate install polaris sportsman, winches for a polaris sportsman
