Won't start - slow turnover - Page 2 - Polaris ATV Forum
post #11 of 25 (permalink) Old 12-20-2012, 04:49 PM Thread Starter
BioJoe's Avatar
thanks
Originally Posted by Boburk View Post
Originally Posted by BioJoe View Post
New Battery voltage when charged and installed 13.3 volts
Old battery was 12.7v. Both aren't turning over unit with any speed. Almost as if batteries are deAd though they aren't.
Engine won't start so I can't give running voltage.
12.7 should have been more than fine for a battery voltage when not running.
03 500 does not have a pull start? If so, you're saying it won't pull start either?
If you try to jump start it, does it also turns over slow? If so, then the problem has nothing to do with the charging system or battery. Then you are looking at starter or associated circuits.
Sean
Maybe it is an 05. eitherway it does have a pullstart and won't start.
I pulled the plug and it still turns slow. I'm guessing it is the starter. Gonna pull it and listen to it spin.
BioJoe is offline
post #12 of 25 (permalink) Old 12-21-2012, 05:30 AM
Boburk's Avatar
I'm confused...so it won't pullstart either but you think it is a bad starter?
Sean
_____
2008 Sportsman 300
- Purchased in 2012 with 25 hours on it
- UNI air filter
- Polaris 1500 winch
2011 X2 550
- Purchased in 2012 with 58 hours on it
- Viper 3500 winch
- Front lock and ride storage box
- Bighorn 2s all around
2012 RZR 570
- Purchased Dec 2013
- Viper Elite 3500 winch.
- Cooter Brown top
- EMP rear window
- Totron 30" curved spot light bar
2006 X2 500 (sold)
- Purchased in 2011 with 250sh hours and 2500sh miles
- 26" Trilobite HD tires on 12" SS108 rims
- Cabela's (Warn RT) 2500 winch
- Front rack extender
- Front brush guard
Boburk is offline
post #13 of 25 (permalink) Old 12-25-2012, 07:26 PM Thread Starter
BioJoe's Avatar
So to clarify. The starter turns the engine over very slowly with or without the spark plug installed.
Pull starting with plug out it spins fine and i didnt hear or feel anything odd And I checked the plug for spark when turning over engine and everything looked good.
So internal mechanical issues don't seem to be at play.
It is hard to pull start with the plug installed though.
BioJoe is offline
post #14 of 25 (permalink) Old 12-26-2012, 04:41 AM
Sounds like starter is bad,should be abkle to pull start though, DB electric on e-bay for starter.
Russ C is offline
post #15 of 25 (permalink) Old 12-26-2012, 05:19 AM
MustBeNice's Avatar
You said you were hunting..... did you go through any water and get water in starter? I'd pull it off and take it appart, clean it up and put back together and see what happens. Not out anything but your free time!
Matthew "MustBeNice"
MustBeNice is offline
post #16 of 25 (permalink) Old 01-02-2013, 06:48 PM Thread Starter
BioJoe's Avatar
No water on the ride. It started kinda weak as if battery was low charge I turned it off after 20min and I wouldn't restart as if battery was dead. So I pull started and rode On. Then 30min later I couldn't get it started with either starter or pull start or a jumper pack.
I have ordered a new starter hopefully that is all it was.
BioJoe is offline
post #17 of 25 (permalink) Old 01-11-2013, 10:45 AM
Dafajha's Avatar
most electrical issues with polaris is the PDM. Mine appeared to be battery also. put new one in and then it was completely dead. if i left the key on for five minutes the power would come on and i could pull start it, then i could start it with the key. next day dead, then it became dead indefinitly. new PDM $190 tax included, runs like a champ! if this is your problem, after install, turn key, leave key on, will take a few seconds before power comes on.
Dafajha is offline
post #18 of 25 (permalink) Old 01-11-2013, 11:14 AM
MustBeNice's Avatar
Good advise.... woudl be worth a try.
post #19 of 25 (permalink) Old 01-11-2013, 07:13 PM Thread Starter
BioJoe's Avatar
Awesome Advice.
Man I hope this is it. I am so tired of spinning my wheels and time but most importantly my $$$. I am all over $200 to put this project to bed and do some ridding.
BioJoe is offline
post #20 of 25 (permalink) Old 02-01-2013, 07:46 PM Thread Starter
BioJoe's Avatar
PDM - Must Be the Problem...
I did some googling and found others having the very same problems and more that what I described previously so let me update my list of what to look for and why.
1. Erratic Fan - turns on and off a lot and at weird times.
2. Voltage - @ 3000rpm should be no more than 15v but no less than 13v. if it is not you have something robbing power like a short.
3. Clean all connections and make them good and tight before doing anything.
these are a few thing I came across.
PDM will be my next thing
BioJoe is offline
Sluggish turnover when trying to start my 2009 850 XP!? Please Help BIG SEXY ATV Repair and Maintenance 12 11-27-2011 04:00 PM
Slow 99' 500? rangerboy101 Polaris Sportsman 12 05-15-2011 07:49 AM
slow 500 bogging sportsman 500 ATV General Discussion 8 01-18-2011 06:11 AM
Will this slow me down? davidhicks ATV Performance Modifications 2 05-20-2010 11:48 PM
4x4 slow to engage thepopeis1 ATV Repair and Maintenance 8 01-21-2010 11:22 AM
