Correct procedure for bleeding ALL the brakes - Polaris ATV Forum
Old 12-17-2012, 02:15 AM
prickle's Avatar
Member #25486
Hi
I need to replace the rear calliper on my 800 so will need / want to bleed the whole system.
Can someone outline the procedure for me please ?
Stuart
Old 12-17-2012, 08:44 AM
KICKER431's Avatar
Member #18006
Just like bleeding the brakes on a car. Easiest if you use a one man brake bleeder bottle. Otherwise you will need two people.
The most important part is to identify which of the rear bleed screws is attached to which brake lever (foot or hand). This should be easy as you will have it apart to replace the caliper. So just remember which is which when you reassemble.
1. attach the 1 man bleeder bottle, or slip a small hose/tube over the end of the bleed screw and place the other end in a bottle/jar with a little brake fluid in it. That way as air bubbles out it can't return air back up the hose. The only thing being sucked up the hose will be brake fluid.
2. With the hose in place, open the bleed screw.
3. open the master cylinder appropriate to the line you are bleeding (Hand or foot)
4. being careful not to splash brake fluid everywhere, or to let the master cylinder go dry (therefore letting air back into the top of the system) depress the brake lever to force clean brake fluid into the brake line fro the master cylinder. Do this 5-6 times and refill the master cylinder. You will find that you have to refill the master cylinder often as these are long brake lines and small master cylinders.
5. When you are confident that all the old fluid and air is purged from the line, close the bleed screw and move on.
6. After all 4 bleed screws are bled, recap the master cylinders. You should now have good stiff brake levers at the hand and the foot. It will probably take a whole pint sized bottle to do all 4 bleed screws. Don't try to save the extra fluid for more than a week or so. It attracts water right out of the air and goes bad easily. On the other hand I recommend keeping it around for a week or so in case you find you left a bleed screw a little lose and need to top it back off again.
completely stock FOR NOW
26" Maxxis Bighorn 2.0
Old 12-17-2012, 01:44 PM
prickle's Avatar
Member #25486
Originally Posted by KICKER431 View Post
............. 3. open the master cylinder appropriate to the line you are bleeding (Hand or foot)
Thanks for the response Kicker
I have had the brakes off for a while .. Can you tell me which connection to the caliper the foot brake lines connects to ???
Stuart
Old 12-17-2012, 02:26 PM
KICKER431's Avatar
Member #18006
Not until I can get home to look at my machines. Might be a few days. Or you could check the online parts diagrams at cheapcycleparts.com or Polaris.com
Old 12-17-2012, 02:28 PM
prickle's Avatar
Member #25486
Thanks kicker ... Will check those sites out
Have a great Christmas
Stuart
Old 12-17-2012, 02:54 PM
prickle's Avatar
Member #25486
All done .... Thanks kicker
Old 01-08-2013, 08:55 PM
katmeef's Avatar
Member #32788
Anytime I bleed brakes on my car I just use gravity.. i loosen the bleeders, remove the brake fluid resevoir cap, and keep topping it up as it leaks out the bleeders. Don't let it run dry in the resevoir! Always works well for me, imagine the same should work with the atv?
2013 Sportsman 500 H.O.
26" Mudtrax XL w/ RDC slip on 1/4" spacers
Polaris HD 3500 LB Winch
Polaris OEM Sportsman Front and Rear Bumpers
Polaris OEM Hand and Thumb Warmers
Polaris OEM Black Handguards
Glacier III plow system
Front Rack Extender
HD front and rear springs
Wes Comfort LnR rear cargo box seat
Ricochet full frame + A-arm skid plates
Foot peg kit & Fender guards
Old 01-09-2013, 01:42 PM
1of7627's Avatar
Member #4155
Another great way to bleed hydraulic systems is to use a MityVac. These are inexpensive vacuum pumps that connect to the bleeder screw and draw the fluid throught the system with a few pumps of the handle. It moves easily from point to point and all you have to do is replenish the master as the fluid is pulled through. Wouldn't think of doing it any other way. Your method may vary. - MarkC
MarkC - Spokane, WA USA
2008 polaris atv brake bleed prsseedure
bleeding brakes on a 2014 polaris sportsman 550
how do you bleed the brakes on a 2014 polaris sportsman 550 touring
how to bleed atv brakes
how to bleed brakes on polaris 4 wheeler
how to bleed brakes on polaris sportsman
how to bleed brakes on polaris sportsman 500
how to bleed polaris atv brakes
how to bleed polaris ranger brakes
polaris sportsman 550 master cylinder
proper way to bleed brakes on 2004 sportsman
sportsman 500 polaris 2012 rear brake bleeding
New 2012 and break in procedure fritzelman Polaris XP 56 05-01-2013 10:57 PM
What's the best cold starting procedure? jpl20 Polaris Sportsman 5 10-21-2011 02:39 PM
Procedure for changing PDM?? eastern_hunter ATV Repair and Maintenance 1 07-31-2011 12:46 PM
Bleeding Brakes Question smc9696 Polaris Magnum 3 09-22-2010 08:48 AM
bleeding brakes on scrambler w/broken master cycl. 425whpsti ATV Repair and Maintenance 2 07-15-2010 11:00 PM
