03-20-2010, 10:55 PM
Member #1666
Help! Oil leak 02 700
need help with 2002 sportsman 700 twin oil leaks what looks like the crank shaft and fills the the clucth cover than it covers the belt and than it starts to slip and smells like burnin rubber , so i take off the cluch cover and degrease the clutch belt and cover and run 50 miles 40mph and it fill's back up ! is this a easy fix? is the seal just behind the clutch? 02 700 twin oil leaks from crank shaft clutch side
03-22-2010, 08:11 PM
Member #1644
never done one myself, but to me it looks like you need to remove the clutch with the proper removal bolt like tool from polaris remove the rear cover and it looks like a tripple or double lip seal... buy one from polaris nd you will get a better ide how to get it out.
04-22-2010, 12:10 AM
Member #1666
to let everyone know it was a 30 somthing dollar crank seal that was bad , i toke the motor out and a friend charged 100 to put in the new one in , but when i got the motor in the motor will not run at high rpm it boggs and dies
03 sportsman 700 leaking oil from side of motor, 03 sportsman 700 oil seal, 2002 700 sportsman crankshaft seal repair, 2002 polaris leaking engine oil side, how do you remove a polaris sportsman crank seal, oil in the poloris clutch housing, oil leak 700 polaris, oil seal 2002 polaris 700, polaris 700 crank seal, polaris 700 sportsman 2002 oil leak from left side cranksaft, polaris 700 sportsman crank seal, polaris 700 twin 2002 crankshaft oil seal, polaris atv 2002 oil leak, polaris crank seal leaking, polaris oil in belt cover, polaris sportsman 700 oil leak, polaris sportsman crank seal, removing crank seal polaris 800 atv, removing rear crank seal from polaris sportsman 700, sportsman 700 crank seal replacement
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Oil Leak
yanks2362 |
ATV Repair and Maintenance |
5 |
02-09-2011 01:48 PM |
dtsesthx |
0 |
03-11-2010 10:59 AM |
Bad Oil Leak
Ozquad |
Polaris Sportsman |
0 |
01-15-2010 08:23 PM |
850 XP Oil Leak
Irondog |
Polaris XP |
3 |
12-14-2009 08:16 PM |
sportsman oil leak
alohman |
Polaris Sportsman |
1 |
12-01-2009 07:59 PM |
