Sportsman 500 Ball Joint Removal - Polaris ATV Forum
Old 03-25-2010, 04:56 PM
ipaman's Avatar
Member #3536
I thought I would share this since I found the info on HL. Once you get your ball joint ready to remove, instead of using the special tool or making one to pull it out there is a much simpler way. Pump grease into the zirk fitting and the joint will just slide out. I just did this and was amazed at how easy it came out.
Here are the original instructions I found. Replace steps 6 and 7 with pumping grease into the joint and you are good to go:
To remove the ball joints:
1. Place machine in Park and/or apply parking brake. Jack up and secure.
2. Remove front wheel (s).
3. Remove Cotter pin and Castle nut.
4. Use a pickle fork or equivalent (I used a drift wedged btwn the lower strut housing and A-arm near the ball joint) to separate the A-arm from the Ball joint stud.
Note: Be sure to support you rotor with a floor jack so the outer CV joint (if applicable) don’t pull apart when the lower A-arm disconnects from the ball joint stud.
*Some may prefer to remove entire strut housing for ease of removing ball joint and pressing in new one with an arbor and press.
5. Remove ball joint cover Plate.
6. Apply heat to strut housing to expand material aiding in removal of ball joint.
7. Use appropriate tool or equivalent to remove old ball joint. I used a piece of adjustable electrical coupling pipe (min. 1 3/8 ID, 1 1/2 preferred) and assorted large washers (used as spacers) with the castle nut threaded on the ball joint stud to remove mine. Began cranking down on the nut and the pipe acts as a puller. Once I ran out of threads, I removed that length of pipe and went with a longer one or added washers, cranking down on the nut again.
Note: Be sure NOT to damage the treads on the ball joint stud as its imperative that the castle nut move freely and easily on stud or the whole joint will spin instead of pull out of strut housing bore.
Old 03-25-2010, 05:06 PM
ipaman's Avatar
Member #3536
Here is a link to the original thread I found. Pulling Lower Ball Joints on my sportsman ???
Old 03-26-2010, 04:12 PM
MUDDIE49's Avatar
Member #858
Thats pretty good stuff...i'll remeber that when i'm ready to replace....Thanks Bud....Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
Old 03-26-2010, 06:39 PM
chopper89's Avatar
Member #1634
that is a neat trick will try to remember that when the time comes.
2014 850 XP EPS BROWNING EDITION
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 03-26-2010, 06:55 PM
ipaman's Avatar
Member #3536
I was able to get mine in easily as well. I placed the ball joint in line and put a socket over it. I then used a BFH and tapped it in. I had to hit it pretty good at one point, but it went in. Took 5 minutes tops.
Old 03-28-2010, 07:58 PM
PolarisJay13's Avatar
Member #3938
Thumbs up Front End Ball Joint Removal
IPAMAN, you are a lifesaver! I had to replace both of my front ball joints on my 03 600, and after failing to pull them myself, I went searching. I found your post, and followed the grease pumping method that you recommended... MONEY! I had both the ball joints out in minutes! I am not looking forward to buying new ones.. however. Thanks again, man.
Old 03-29-2010, 04:26 AM
ipaman's Avatar
Member #3536
Sweet! The same thing happened to me thats why I posted this. I hoped it would help someone else. Mine went in easily using a socket and hammer.
Old 12-15-2010, 06:09 AM
Gator Pit's Avatar
Member #10145
Hello everyone. Have a questions, but first a little history that led me here. This past Saturday, I purhased a 2001 Polaris Sportsman 500 HO. Other than the ball joints and a few other normal wear and tear issues, the ATV is in good shape. The previous owner had all the oil, filters, differential oil changes, plug, service records, etc. Unfortunately, he feel on hard times and needed to sell it. I knew it needed some repair work, ball joint replacement, new brake pads front and rear, and some other minor such fixes/repairs.
Here is my main question: The right ball joint broke. I have managed to pull out the left ball joint THANKS to you guys. I know how to get the broken bolt out of the control arm. Vice and BFH will knock that out I am sure. What do you recommend as the best way to remove the remaing ball joint that is in the strut? I am thinking Heat, based on your posts. I will purchases a small torch for this today and try this after work this evening. Unless you guys have a better way/suggestion.
Second Question: What is the best way to inserting the new ball joint? Again, Heat? and/or combo of heat or just using something to assist in tapping the new joint into the strut?
I thank you all for your assistance and look forward to hanging out here. I have never had a four wheeler ATV, but am not unfamiliar with motorcycles as I have had bikes both dirt and street since I was 4 years old. Four wheelers are a slightly different breed.
I am looking forward to getting my Sportsman up and running to enjoy. It has 28 x 10 x 12 mudzillas on front and 28 x 12 x 12 mudzillas on rear, brand new, along with a few other features the previous owner added.
Old 04-09-2013, 01:31 PM
Codyryanlong's Avatar
Member #35426
Sportsman balljoint replacement
My balljoint broke while riding on my polaris sportsman 700. After reading several post about pumping in grease into the fitting and using a peace of pipe and washer to retreve the balljoint casing from the strut housing. All to no avail. My dealership said they normally replace the strut housing for 287$!! As a last resort I used an oxycedlene torch and heated the housing for several minites, poured a cap of water into the case there the ball and stud once was, then used pliers to retreve the case with ease!!
I hope this helps others.
Old 04-10-2013, 07:12 AM
TXRonnie's Avatar
Member #17937
Remember to put the new ball joint in the freezer for about an hour before you put it in. Freezing it will shrink it some and it will be much easier to get in.
Ronnie
05poleris sportsman400 bolljoint
2009 polaris 800s rear differwrinchel
97 sportsman 500 ball joints
how to change lower ball joint on 2005 polaris sportman 500
how to change lower ball joint on polaris sportsman 450
how to remove ball joint on polaris sportsman
how to remove polaris sportsman ball joint
how to take ball joint out of lower a-arm on fourwheeler
lower ball joint polaris sportsman
polaris ball joint removal
polaris ball joint removal tool
polaris sportsman 500 ball joint removal
Discontinued ball joint??? HighPlainsDrifter ATV Repair and Maintenance 5 01-25-2010 01:14 PM
Front C V Joint shot `03 Sportsman 700 Dodgeboy ATV Repair and Maintenance 4 01-09-2010 06:51 PM
Lower Ball Joint for '88 Trail Boss HighPlainsDrifter ATV Repair and Maintenance 2 11-10-2009 05:59 PM
Front ball hitch for my 500? mudslinger Polaris Sportsman 5 11-09-2009 04:48 PM
99 sportsman 500 cv joint adavis ATV Repair and Maintenance 3 08-05-2009 07:50 PM
