Float bowl drain ???? - Polaris ATV Forum
post #1 of 4 (permalink) Old 03-09-2013, 02:33 PM Thread Starter
PolarisRich's Avatar
I have a 05 500, when I bought the quad it never had a drain tube on the carb drain valve. I decided to put a new drain tube on with a Polaris check valve but I dont know where the best place (Stock route) is to route the tube.
I installed it and thought it would be better to run the tube on the clutch side between the backside clutch cover and the block, near the oil filter and down to the frame.
Is this an OK place to route the tube and where is the stock location route?
2005 Polaris Sportsman 500 HO
26" Mudlite XL's, Clutch Kit, 3 Headlight Mod, 1/4" Front Wheel Spacers, 1" Front Spring Spacers, Uni Filter, Heated Grips, 12V Electrical Accessory Panel, Etrex GPS Handlebar Mount and hardwire, Passenger Seat with Cargo, Horn, Snorkeled Vent Tubes, Mossy Oak Graphic Vinyl Wrap, 2500 Runva Winch, ShockPro's Camo Shock Covers
PolarisRich is offline
post #2 of 4 (permalink) Old 03-09-2013, 04:00 PM
4getful2's Avatar
On my '03, it's on the clutch cover side, in the back and back down to the earth.
4getful2 is offline
post #3 of 4 (permalink) Old 03-09-2013, 04:50 PM
Dont use any check valve, take it to the dirt.,
Russ C is offline
post #4 of 4 (permalink) Old 03-09-2013, 04:52 PM Thread Starter
Why not?
I do a lot of deep water riding and I want to keep the water out.
Size of carb bowl drain line rhinnc ATV Repair and Maintenance 1 02-17-2013 08:18 PM
Gas leaking from carb bowl vent line Popeye ATV Repair and Maintenance 5 12-12-2012 06:13 AM
carb bowl drain tube leaking while reaving ducker1 ATV Repair and Maintenance 3 07-15-2012 04:11 PM
hose nipple on bottom of carb fuel bowl gjones1 ATV Repair and Maintenance 2 10-08-2010 03:09 PM
1998 Trail Boss 250 Carb Bowl tonydaddy1 ATV Repair and Maintenance 1 10-05-2010 03:31 PM
