07 500 Sportsman Check Engine light - Polaris ATV Forum
post #1 of 16 (permalink) Old 04-06-2013, 07:07 PM Thread Starter
Fuzzybear's Avatar
Post 07 500 Sportsman Check Engine light
Hi Guys.
I have a 500 EFI HO and it has developed a bit of an issue.
It started with a check engine light (which I did and found nothing a miss, so I started it up and it went away).
Later on that ride the bike developed a stall at low idle and became hard to start after it stalled, it would even blow a bit of blue / white smoke on getting it going.
At the end of the ride i noticed the ols spanner came up and was blinking so i knew it was due for a service.
This morning I went to start to warm up the oil for the service and the check engine light is back on and the bike was very hard to start again.
I checked the oil level and low and behold the oil level is way over full.
The coolant level is good (oil is not milky) but i would hazard a guess that it will be fuel in the oil as it does smell a little that way.
Any one able to tell me how to pull up the fault code and test my injection system to see where my issue lays?
Regards Fuzzybear
Fuzzybear is offline
post #2 of 16 (permalink) Old 04-06-2013, 07:16 PM
Corbett1973's Avatar
Try draining the oil & refill it with new oil. 2qts should all be needed, mine had a similar problem & thats what I did. Welcome to the forum!
07 500 EFI HO X2 Deluxe
25" Original Bighorns
Polaris HD Front springs front & rear bumpers
money is the root of all evil & man needs roots:
Corbett1973 is offline
post #3 of 16 (permalink) Old 04-06-2013, 07:59 PM Thread Starter
Fuzzybear's Avatar
Thanks for the Welcome.
I have drained the oil, but i am a bit concerned that it will do it again !
post #4 of 16 (permalink) Old 04-06-2013, 11:15 PM Thread Starter
Fuzzybear's Avatar
Unhappy
Ok Service done but I still have a "Check Engine" on.
I removed the fuel tank and cleaned out all the old fuel and refilled it.
It is idling now but it does have a bit of a flat spot just above idle and will often die with a bit of a back fire?
post #5 of 16 (permalink) Old 04-07-2013, 01:06 AM
AKStew's Avatar
Check the boot connections between the throttle body and the engine.
What code is it?
Stew
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
AKStew is offline
post #6 of 16 (permalink) Old 04-07-2013, 01:14 AM
AKStew's Avatar
Based on your symptoms I would guess it's the MAP sensor or its wiring harness. The wires tend to break inside the insulation at or near the sensor. They will look good but if you tug on them a broken one will feel stretchy. A better than oem replacement harness can be had at http://otbpowersports.com/
Stew
AKStew is offline
post #7 of 16 (permalink) Old 04-07-2013, 01:19 AM
AKStew's Avatar
To get the code turn the key on 3 times in 5 seconds leaving it on the third time. Count the blinks of the check engine light and write it down. There will be a slight delay between digits. E.g. 1-2-2-1-5-2-6-1.
AKStew is offline
post #8 of 16 (permalink) Old 04-07-2013, 03:35 PM Thread Starter
Fuzzybear's Avatar
Ok The Numbers Were. 1. 3. 4. 5. 4. 6. 6. 1.
post #9 of 16 (permalink) Old 04-07-2013, 04:23 PM
AKStew's Avatar
The codes are 13, 45, 46, & 61.
I've never seen 13 but I'm pretty sure it's just a marker to begin the sequence. 61 means it's the end.
45 and 46 are both for the MAP sensor low and high input respectively. That means your voltage signal from the MAP sensor is all over the place or nonexistent at times. The sensor itself would be really hard to damage so I suspect the wiring harness is bad. It's a very common problem.
I would replace it with the one at the link I posted earlier. It's really easy and comes with everything you need.
Stew
AKStew is offline
post #10 of 16 (permalink) Old 04-07-2013, 04:54 PM
Rooftop777's Avatar
I know one of my efi 500 s were acting strange years ago. I would ride then quad would act up and sputter then the needle on gauge would blink. After 3 months of issues I figured out my stator was bad. But you don't have that issue otherwise your battery would always be dead because not charging. Someone told me once a low battery does affect efi machines more than others becuase it depends so much on good voltage. Check that you battery is good and that its getting charged........just thought......
2007 Polaris Sportsman 500 EFI, Black Metallic, Polaris aluminum rims, Mudlites, Warn 2500 winch, front and back bumpers.
2012 Project rebuild:2007 Polaris Sportsman 500 EFI, Red/Orange, Polaris aluminum rims, Maxxis, front and back bumpers.
2015 Project Rebuilt: 2009 Polaris Sportsman 500 EFI X2, Green Metallic, Polaris aluminum rims, Bear Claw, Polaris winch, front and back bumpers.
Rooftop777 is offline
2006 sportsman 500 efi check engine light model70 ATV Repair and Maintenance 6 04-27-2014 03:34 PM
2008 Sportsman 800 check engine light Bud Polaris Sportsman 4 10-06-2012 06:40 AM
2008 Sportsman X2 check engine light Boburk ATV Repair and Maintenance 1 08-11-2012 04:30 PM
2005 Sportsman 400 Hot and Check Engine Light on Sorrey Polaris Sportsman 10 05-16-2012 06:41 PM
07 800 sportsman AWD & Check Engine Light Unistoner ATV Repair and Maintenance 4 04-25-2010 08:13 PM
