Ball Joint removal - Polaris ATV Forum
Old 04-08-2013, 06:40 PM
WalterS's Avatar
Member #12678
Ball Joint removal
When removing the ball joints, after taking off the retaining plate, and applying heat, what is the best way to actually remove the ball joint?? Is it necessary to use a specialized removal tool/puller?
2006 Sptsman 800
2007 Sportsman 800
1500 miles, mostly at Hatfield-McCoy trails, WVa.
Old 04-08-2013, 06:45 PM
Trip's Avatar
Member #26001
Job would be much easier with a balljoint press.
C clamp. Pipe an washerS
2012 Sportsman 800
-Engine
-4 Tires
Old 04-08-2013, 06:50 PM
Member #1958
Piece of pipe and some washers.
Old 04-09-2013, 05:37 AM
PolarisRich's Avatar
Member #7183
First try pumping grease into them! If they have ever been changed before maybe you have put greaseless ball joints back in, and if so they will just pop right out when you grease them, of course thats if you've removed the retaining plate first! Right!!
2005 Polaris Sportsman 500 HO
26" Mudlite XL's, Clutch Kit, 3 Headlight Mod, 1/4" Front Wheel Spacers, 1" Front Spring Spacers, Uni Filter, Heated Grips, 12V Electrical Accessory Panel, Etrex GPS Handlebar Mount and hardwire, Passenger Seat with Cargo, Horn, Snorkeled Vent Tubes, Mossy Oak Graphic Vinyl Wrap, 2500 Runva Winch, ShockPro's Camo Shock Covers
Old 04-09-2013, 06:22 AM
Talon's Avatar
Member #23484
A little long, but here's a video.
Craig
2011 850XP EPS, Roctane tires, 3000lb winch
2013 850XP LE, Glacier III Plow
Old 04-09-2013, 06:35 AM
TXRonnie's Avatar
Member #17937
I put a little heat around the ball joint. Leave the nut on the end of the joint and clamp a set of vice grips on the joint just above the nut. Hit the vice grips with a hammer and they always pop right out for me. Put the new one in the freezer for about an hour then put the new one in. Really simple job.
Ronnie
Old 04-09-2013, 07:22 AM
Centexguy's Avatar
Member #27923
What he said. ^^^
2001 Sportsman 500HO DUSE
Old 04-09-2013, 08:03 AM
WalterS's Avatar
Member #12678
So... you shouldn't have to remove the strut to remove the ball joint then? What about if I am replacing the bearing also, does the strut have to come out for that?
2007 Sportsman 800
Old 04-09-2013, 10:15 AM
Centexguy's Avatar
Member #27923
Nope on both accounts.
Old 04-12-2013, 05:33 PM
Dave413's Avatar
Member #35004
Ronnie
I do believe this just saved me a few hours of extra dismantling for sure. Thanks!!
2000 Sportsman 500
2005 polaris sportsman 800 ball joints
2007 sportsman 800 ball joint change
2007 sportsman 800 lower ball joint removal
850xp bottom balljoint popping on front
ball joint
ball joint press for polaris rzr
how to change lower ball joints on polaris ranger 2005 500
polaris 500 ball joint removal
polaris 800 2005 front ball join change
polaris ball joint removal tool
polaris ranger ball joint removal
polaris rzr ball joint puller
Sportsman 500 Ball Joint Removal ipaman Polaris Sportsman 24 12-11-2015 11:45 PM
94 400L 4x4 lower ball joint removal help DwightCobra Polaris Sportsman 5 01-06-2012 08:59 AM
05 sportsman front lower ball joint removal mv7 ATV Brakes & Suspension 3 12-25-2011 06:03 AM
Strut ball joint removal and install? JML66 Polaris Sportsman 1 12-15-2011 11:45 AM
Bad ball joint or not? ...plus A-Arm removal tip. scottdeet ATV Repair and Maintenance 11 03-22-2011 07:00 AM
