Old 04-07-2010, 03:34 PM
Ilovemylemon's Avatar
Member #4160
2007 450 polaris sportsman
I was told last year that it skipped timing and the valves tightened, $400.00 This year, will not start with key but it will start with rip cord. the amount of times it take too pull start it is getting longer and will not idle when it is started. Gas was pouring out of the carb drain. Changed float, needle valve, ran sea foam in gas and crank case for one tank of gas. changed oil, spark plug and put high test in it. ran great for about 6 miles, next week back to square one. I have checked and set the throttle cable, new battery, new plugs, filters. I am ready to buy a new starter, but I would like to hear that is the problem before spending the money, help
Old 04-07-2010, 04:40 PM
have you tried jumping the start solenoid. if its one of those two with the e-start problem, jumping the start solenoid will tell you either way?
Old 04-08-2010, 03:57 PM
Member #4160
thanks blueline, I will try it. I tried getting it to start with the rip cord today and it wants too but it just will not turn over. I turn the key and it sounds like it is going to fire but will not, thanks again
07 450 sportsman camshaft
2007 polaris 450 sportsman valve adjustment
2007 polaris 450 sportsman valve clearence
2007 polaris 450 throttle cable adjustment
2007 polaris 450 valve clearance
2007 polaris sportsman 450 valve clearance
450 polaris sportsman spark plug 2007
450 sportsman not starting
camshaft timing 450 sportsman
like new 07 polaris 450 sportsman
polaris 2007 450 for sale
polaris 450sportsman idle adjustment
polaris outlaw 450 valve clearance
polaris sportman 450 wont idle
polaris sportsman 400 turn key wont start
valve adjustment sportsman 450
valve clearance for outlaw 450
valve timing 2007 sportsman 90
what is the valve clearance for a 2007 450 polaris sportman
2007 Polaris Sportsman 500 - $4,500.00 getwwa ATVs For Sale 5 03-10-2010 04:26 PM
2007 Polaris Outlaw 525 redneck2725 2007 1 02-28-2010 02:59 PM
2007 Polaris Predator 500 redneck2725 2007 0 02-28-2010 02:45 PM
2007 Polaris sportsman 500 dead! mutt3497 Polaris Sportsman 11 01-31-2010 02:57 PM
2007 Polaris Outlaw 525 IRS bmerriman12 ATVs For Sale 6 05-23-2009 07:50 AM
