Old 04-09-2010, 04:38 AM
Mike109's Avatar
Member #4125
Unhappy No 4wd in reverse
Hello! New to this site and could really use some help!
I have a 2008 Sportsman 500 HO EFI. While riding this weekend in N. Georgia, it started acting funny. I needed to use 4wd in reverse to turn around on a steep incline and no 4wd.... The yellow button was pushed in, the display indicated 4wd, slow, slow, slow.. etc... but no 4wd in reverse. I tried it several other times throughout the day with no luck. Any help would be appreciated? Thank you!
Mike
Old 02-03-2012, 05:37 PM
tinner1997's Avatar
Member #22253
Hey Mike, I just went through a similar problem on my 2009 500 EFI X2. Check to see if can you access the diagnostic mode or the service features on your pod? If not ,it sounds identical to my problem. I was able to trace the wiring back to the pod but couldn't go any farther. I took to my dealer and he found two wires broken in the harness. Quick solder job and back in business. I still plan on contacting Polaris and bitching...I beat the crap out of my last Polaris and never had this kind of problem..My 09 isn't even broken in yet.....We'll I hope this will give you someplace to start..Good luck...Andy
Old 02-04-2012, 12:03 AM
bosnjo's Avatar
Member #18373
Don't take me too seriously, as I read it somewhere long time ago and may have it distorted in my memory, but it said no 4WD in reverse until you hit override button.
Again, it was long time ago...
2011 Sportsman Touring 850 EPS
------------- Portugal --------------
- Wind deflectors
- Rear motorcycle box
- Front Brush Guard
- Car tires
- GPS Garmin Dakota 20
- Road legal
700 sportsman no 4wd in reverse
are polaris sportsman 4wd in reverse
no 4wd in reverse polaris
no 4x4 in reverse polaris
no awd in reverse polaris 700
polaris 2003 700 sportsman no 4x4 in reverse
polaris 500 efi no awd in reverse
polaris 500 sportsman no awd reverse
polaris sportsman 400 no 4 wheel drive
polaris sportsman 400 no 4 wheel drive in reverse
polaris sportsman 400 no 4x4 in reverse
polaris sportsman 500 no 4x4 in reverse
polaris sportsman awd reverse
polaris sportsman no 4wd reverse
polaris sportsman no awd in reverse
polaris sportsman wont go in reverse
polaris stortsman no awd in reverse
sportsman 500 ho awd reverse
4x4 reverse override ploughboy ATV Repair and Maintenance 3 02-10-2010 10:36 AM
reverse override kclidwell ATV General Discussion 4 01-31-2010 05:31 AM
no 4wd in reverse Austin61 Polaris Sportsman 9 01-16-2010 06:47 AM
sportsman has no reverse azdave35 ATV Repair and Maintenance 3 01-01-2010 05:45 AM
4x4 not working in reverse canyonyoddler Polaris Sportsman 2 12-15-2009 05:29 PM
