Superwinch install question - Polaris ATV Forum
Old 05-28-2013, 12:24 PM
abranz's Avatar
Member #36281
Hi, new member here with a 2013 sportsman 500. I bought a superwinch lt2500 and installed it but have a question regarding their circut breaker. Its two 50amp breakers on a buss bar which is not insulated at all. instructions say to wrap in electrical tape. I've installed many winches from warn and others and this is the first one with a circut breaker.
Are these winches different than others thus requiring a breaker? It looks like any other atv winch from china I've seen or installed and has similar amp draw.
Any thoughts on how to insulate it to prevent short circuiting it other than the proposed electrical tape idea which is a piss poor method to say the least.
Thanks Anthony
Old 05-28-2013, 12:51 PM
1of7627's Avatar
Member #4155
Radio Shack sells a large diameter shrink tube (something like an inch diameter or so) like the stuff used to hold thumb warmers on the throttle levers. Would something like that be large enough to slip over the buss bar?
MarkC - Spokane, WA USA
Old 05-28-2013, 12:57 PM
abranz's Avatar
Member #36281
Not sure if I can find a piece that wide but ill give it a try. I see your in post falls. I'm in Wallace and just bought this machine from cda polaris. Anyway superwinch absolutely should have supplied some method of insulating this unit. I cannot believe it hasn't caused fires followed by lawsuits. I'm not joking, it's two breakers mounted in parallel to two pieces of bare aluminum.
Old 05-28-2013, 01:10 PM
1of7627's Avatar
Member #4155
Can't say that I've seen the Superwinch installation like you describe, but I know the install of my $70 Master Lock (from Wal-Mart) winch would REALLY make you laugh! (Visualize a wired hand-held remote with no contactor and all current passing through the cables, and no lock on the remote to prevent it from being accidentally actuated when stuffed in a compartment.) I'll replace it with a real winch someday.
Got my '09 from CdA Polaris too. Small world, eh? It's a pleasure to see another Idahoan on the forum! - MarkC
Old 05-28-2013, 01:12 PM
MustBeNice's Avatar
Member #29059
Breaker vs. Fuse a user friendly and good idea..... no insulation on bars, would be a poor idea!
How about liquid electrical tape or plasti dip (basically same thing)??? I would think this would prevent your concerns of "arching and sparking"!?!?!
Matthew "MustBeNice"
Mods: Polaris 2500HD Winch - Synthetic Rope - MotoAlliance Line Stopper - Glacier3 60" Plow - Polaris Rack Extenders - Polaris Bumpers - LowPro Shield - Polaris Hand Guards - Warning Debadge - 3Way Head Light (Relay) - Cabelas Mirrors - Wes Ind. Std Seat/Box - Kolpin Fuel Pack Jr - 26" ITP MudLite Tires - HighLifter HD Springs - MotoAlliance Sirius 6" Pro LED Light Bar
Old 05-28-2013, 02:06 PM
Nitro's Avatar
Member #8438
Re: Superwinch install question
I installed a winch on my quad a couple months ago and ran into the same issue. I think most people mount the fuse/breaker bar directly to the battery. Didn't work for my battery so I got an extesion cord coupler cover and modified it so it would fit inside to insulate it from the frame.
Sent from my ADR6350 using Tapatalk 2
2002 Sportsman 400
Old 05-28-2013, 02:39 PM
MustBeNice's Avatar
Member #29059
^^^ That's good thinking too!!
Old 05-28-2013, 02:59 PM
abranz's Avatar
Member #36281
where would I find an extension coupler cover? Honestly have not seen one. Anthony
Old 05-28-2013, 03:59 PM
Nitro's Avatar
Member #8438
Should be able to find them at any hardware store. I had to modify mine by cutting out ribs inside to get it to fit but it worked as was cheap. The bigger the better.
Cord Connector-Orange at Menards
Another link to the same item w/ more pics
Water-Tight Locking Extension Cord Connector
2002 Sportsman 400
Old 05-28-2013, 04:29 PM
hatzie's Avatar
Member #29903
I used a pair of insulated power distribution studs in place of the cable bolts.
Similar to this one.
Amazon.com: Insulated Distribution Stud, 3/8 Inch, Red: Sports & Outdoors Amazon.com: Insulated Distribution Stud, 3/8 Inch, Red: Sports & Outdoors
The insulated bases bolt to the side of the battery box. I hosed the entire assembly down with Wurth HHS 2000 after installing the cables... Fluid Film or any other spray di-electric grease will work the same.
2013 sportsman 500 superwinch mounting kit
how to wire a superwinch lt2500
super winch lt2000 wiring for 1997 polaris sportsman 500
super winch pm 3000 load direction
superwinch circuit breaker
superwinch circuit breaker installation
superwinch lt2500
superwinch lt2500 atv winch polaris 400 2005
superwinch lt2500 installation instructions
superwinch terra 35 installation fuse
superwinch terra 45 100 amp circuit breaker
where to mount circuit breaker on polaris sportsman winch
Superwinch LT3000 Install Stockfordx2 Polaris Sportsman 2 08-20-2012 05:12 AM
2010 850xp Superwinch Terra 35 wire tap into question jplumb ATV General Discussion 2 05-05-2012 06:39 AM
Superwinch Terra 25 install question danxrs05 ATV General Discussion 0 04-24-2012 12:08 PM
Winch install question blaryslawn ATV General Discussion 10 10-23-2011 07:44 PM
Superwinch install Help/Suggestions! AndymcXP850 Polaris XP 1 04-10-2011 03:28 PM
