Old 04-11-2010, 04:09 PM
MudslingingSooner's Avatar
Member #4198
Question Sportsman 800 touring Big Bore Kit
From what i understand the sportsman 800 engine is the same as the RZR engine right? Does anyone know if the Holz racing or Muzzys big bore kits for the RZR will work on the 800 sportsman?
Old 04-12-2010, 04:17 PM
denseleit's Avatar
Member #2441
Same engine, all parts transfer over. The rzr s cam is the same as the sportsman HO cam. If you go big bore, I'd go with ported head and bigger cam and 11 to 1 compression for sure...
2009 Sportsman XP 850 W/30" ZILLA'S, Team industries 14% gear reduction kit & high altitude clutch kit,3.5 degree advance key,heated grips,superwinch terra 4500,.
2011 RZR w/28" Zilla's, superatv springs, seatbelts and bunch of goodies.
2002 33' Tahoe toy hauler
2008 F350 FX4 crew cab diesel,spartan tuned,S&B,4" back.
Old 04-13-2010, 02:31 PM
Member #4198
thanks for the info, do you have engine work done to any of yours? or do you know anyone with a big bore kit/cam/high compression pistons? trying to see if its worth it, im sure the power difference is worth it but as far as dollar amount and reliability trying to get some opinions or thoughts from people that have gone that route.
Old 04-13-2010, 04:30 PM
denseleit's Avatar
Member #2441
Normally if I'm going to spend big dollars on an engine build or something, I don't like to take short cuts. I've rebuilt my 800 recently blue printed it, mostly stock stuff in it but I've got a strong back ground in building my own drag engines for my mustang race car. Alot of the theorys carry through from one to another. If you go bigger displacement, you need more airflow to make the difference which will come from the ported head. If you dont go with a bigger cam, you will lose rpm of your motor because it will be trying to choke itself at a higher rpm. The cam will hold the valves open longer which will in turn make more power and torque.
Old 04-13-2010, 07:23 PM
denseleit's Avatar
Member #2441
Just wanted to add another part, HPD performance has a big bore kit and what I believe to be the best piston design so far with the best quench. Thats the on I'd go with..
05 sportsman 800 engine rebuild kit
2005 polaris 800 atv bigbore kit
2005 polaris sporman 800 big bore kit
800 polaris sportsman high performance engine rebuild
800 sportsman engine rebuild kits
big bore kit polaris 800 sportsman
engine rebuild kit for sportsman 800
polaris 800 big bore
polaris 800 big bore kits
polaris 800 sportsman stroker kit
polaris atv big bore kits
polaris sportsman 800 big bore kit
polaris sportsman 800 clutch kit
polaris sportsman 850 big bore kit
sportsman 550 big bore kit
sportsman 800 gear reduction
sportsman 800 stroker
stroker motors polaris sportsman 800
top end kit for 2006 800 sportsman atv
2010 touring seat fit an 09 touring? HONDARACER Polaris Sportsman 3 03-29-2010 10:49 PM
08 Sportsman Touring 500 newrider ATVs For Sale 1 01-29-2010 09:56 AM
Dirt wheels best 4x4 big bore terb Polaris Sportsman 13 01-16-2010 10:04 PM
08 Sportsman 800 EFI Touring rider2421 ATV General Discussion 2 01-03-2010 06:41 PM
96 Trail Boss bore diameter chewy1010 ATV Repair and Maintenance 2 10-13-2009 08:24 PM
