2004 polaris sportsman 500 front diff - Page 2 - Polaris ATV Forum
  #11 (permalink)
Old 06-13-2013, 04:44 AM
MustBeNice's Avatar
Member #29059
If you are building/fabricating a hybrid mud wheeler.... I would say central hilliard would be the better of the two..... one unit as apposed to two hub = twice the moving / operating parts. I'd look for one from a model year 2004-2007 size 300cc-800cc sportsman, magnum, or ranger. As these are the ones that can be built with the cheaper & better John Deere parts. As the John Deere Roller Cage is Aluminum vs. Polaris Poly Cage, all other parts should be the same only cheaper!!!
Check this thread out for reference: John Deer Front Diff. parts fit Sportsman!
Matthew "MustBeNice"
Mods: Polaris 2500HD Winch - Synthetic Rope - MotoAlliance Line Stopper - Glacier3 60" Plow - Polaris Rack Extenders - Polaris Bumpers - LowPro Shield - Polaris Hand Guards - Warning Debadge - 3Way Head Light (Relay) - Cabelas Mirrors - Wes Ind. Std Seat/Box - Kolpin Fuel Pack Jr - 26" ITP MudLite Tires - HighLifter HD Springs - MotoAlliance Sirius 6" Pro LED Light Bar
  #12 (permalink)
Old 06-13-2013, 06:09 AM
97polaris500's Avatar
Member #9326
Ya thats what I was thinking , thank you ill post build pictures as soon as I start.
  #13 (permalink)
Old 06-13-2013, 11:17 AM
Member #9326
Another question I have is the motor I'm going to be using is out of a 97 polaris scrambler now from what I can tell the motors are the same except for the stator hook up different. Could I just slice a connector onto my 97 stator and should I just buy a stator for a 05 sportsman and put it on my motor??
  #14 (permalink)
Old 06-14-2013, 09:22 PM
Member #9326
bump!
  #15 (permalink)
Old 06-18-2013, 02:46 PM
Member #9326
another question i have it i came across a 2011 polaris sportsman 500 wiring harness in a parts lot i bought. is there a difference in the wiring from 2005 to 2011?
  #16 (permalink)
Old 06-18-2013, 06:30 PM
InRBigness's Avatar
Member #7218
go central Hilliard and put in an aluminum Sprague cage. Stronger and much more reliable. No more 3 wheel drive. It either works or doesn't and the wiring is out of the way.
08 Sportsman 500HO
01 500HO Plow Machine
  #17 (permalink)
Old 06-21-2013, 08:57 PM
Member #9326
i have a buddy that has a 06 sportsman 500 x2 front diff. would this work with my setup and im going to be using a 2010 frame
  #18 (permalink)
Old 06-23-2013, 08:59 AM
Member #9326
bump!
  #19 (permalink)
Old 06-24-2013, 01:51 PM
Member #9326
anyone is there a difference between the x2 500 and a h.o 500?
08 sportsman 500 front diff john deere
2002 polaris sportsman 400 review
2004 500 ho sportsman front gearcase
2004 polaris scrambler 500 front end differential
2004 polaris sportsman 400 4x4 parts cheaper through john deere
2004 polaris sportsman 500 atv 4x4 problems with front diff
2004 polaris sportsman 500 front differential
2004 polaris sportsman 500 ho front differential
2004 sportsman 500 front differential
2004 sportsman 6x6 500 front driveline rplacement
ebay front gear case 2004 500 ho sportsman
2004 Polaris Sportsman 700 front diff noslofivoh ATV Parts for Sale 2 04-08-2015 04:11 AM
2004 500ho front diff 2 little wires that come out donkey Polaris Sportsman 2 04-01-2015 10:36 PM
2004 Sportsman Front Diff Torque Specs - Help Please playtowinpb ATV Repair and Maintenance 2 02-12-2014 03:17 PM
2004 Sportsman 700 Front Diff plug thebigd ATV Repair and Maintenance 8 10-03-2010 11:52 AM
Polaris Sportsman front diff forest1175 ATV Repair and Maintenance 0 05-05-2010 01:34 PM
