04-25-2010, 02:38 PM
Member #2255
boot change
Tore a front outer boot.
Bought a new boot and a Clymer manual.Went at changing it today.All went real smooth really.Very good manual.
However when trying to disassemble the outer CV joint the drive axle came out of the hilliard clutch assembly.
No big deal it goes back in no problem.
However this is a new machine.The shaft and splined opening For the shaft were bone dry and rusty.Got the boot on and am ready to reassemble
Thought I would hold off to see if there is suppose to be some sort of grease in that end.
Couldn't find the answer in my book.I'm sure it is there.Just couldn't find it.
Appreciate any info
2010 Sportsman 500 HO
Orange Madness
2001 Suzuki King Quad 300
2002 Suzuki King Quad
04-25-2010, 02:56 PM
Member #3583
My 2010 850 Service manual states to put some anti-seize compound on the splines.
Jerry
2010 Red 850 "T" & '08 700 Camo Grizzly w/ EPS & '07 700 Camo Grizzly w/ EPS
04-25-2010, 04:03 PM
Member #2255
Thanx Tumbleweed
I finally found that in the Clymer .Now what is anti-seize compound?
Orange Madness
04-25-2010, 04:57 PM
Member #1634
Originally Posted by murthebear
Thanx Tumbleweed
any good hardware store carries it normaly its used on wheel studs or any bolts and nuts you want to take apart in the future or when you have two dissimliar metals touching each other. google mcmaster carr and look it up theres an automotive grade will be fine or marine grad which is better.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
2006 polaris ranger front boot guard, 2006 polaris sportsman 800 axle boot, change frontcvboot polaris sportsman 2005, change hv boot on 2006 polaras, how do i replace the front cv boot on 2002 polaris sportsman, how to change a cv boot on a polaris sportsman, how to change back axle boot on polaris ranger, how to change cv boot a polaris atv, how to change cv boot on polaris ranger, how to change cv shaft on polaris 4 wheeler, how to change front axle boot on honda four wheeler, how to change front outer boot on a polaris 300, how to change inner cv boot on polaris ranger, how to change outer cv boot quickly, how to change rear outer boot in polaris sportsman 450, how to fix a 500 ho atv cv axel, how to get the axle off 450 sportsman, how to put a cv boot on a 02 polaris 500 ho, how to replace rear boot on 2002 700 polaris fourwheeler, how to take off boot on polaris ranger
