crazy vibration - Polaris ATV Forum
Old 04-25-2010, 04:10 PM
Goose's Avatar
Member #4373
Exclamation crazy vibration
When driving around the yard today I got a crazy vibration almost sounds like heat sheild on exhaust but it is tight. Then when I first fired it up and backd out gotta vibration on the left rear first fibration is front and right near the motor ne ideas
Old 04-25-2010, 04:27 PM
sportsman700's Avatar
Member #4022
Im no expert but i got back from riding last week and had a real weird vibration. I looked on this site and found that the belt might be bad. Ordered another one and installed it yesterday. Vibration gone. Just wanted to let you know. The vibration was not real bad but bad enough to be concerned. It started out when you were going slow but kind of went away once you went faster. Maybe this is your problem? Hope this helps.
Old 04-25-2010, 04:33 PM
Goose's Avatar
Member #4373
Yes but would it be the front one or rear one. I also went through some serious mud. should I Drain the belt case?
Old 04-25-2010, 06:04 PM
chopper89's Avatar
Member #1634
i would just mine 2 cents.
2014 850 XP EPS BROWNING EDITION
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 04-25-2010, 06:20 PM
Goose's Avatar
Member #4373
drain it and think it will be fine ?? Sorry I am new to the ATV world
Old 04-25-2010, 07:19 PM
chopper89's Avatar
Member #1634
to drain it you will have to take the cover off and when you do that inspect your belt, usauly just from driving them they dry out but there might be water still inside the cover. and if your belt is bad they give off a bad vibration feels like the machine is gonna fly apart. if its hourglassed from slipping it gives a slight vibe and this might be what your feeling too. look at the sides and see if there the same width. if you see a diffrence in one part from the other thats hour glass wear if your missing lugs thats the usaul its wear out. if you see any of this time for new belt. there about 75 bucks.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP 27 XTR TIRES
Old 04-25-2010, 07:22 PM
Goose's Avatar
Member #4373
so is it just bolts that hold the cover on? no special tool needed and i ahve seen them online for like 35
Old 04-25-2010, 07:45 PM
chopper89's Avatar
Member #1634
sounds right for aftermarket I was talking a polaris belt. no special tools you will have to pull the rear fenders and footrest out and there like a dozen or more torx head bolts that hold it on cant remember the exact size like a 25 0r 20. to get the belt off you gotta pull straight up real hard and you will see the clutch plates seperate and then you can spin off your belt when you get enough slack.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP 27 XTR TIRES
Old 04-25-2010, 07:51 PM
Goose's Avatar
Member #4373
should i just try driaing water first then tear into it. also what about the noise coming from the right side near my leg of the motor exhaust?
Old 04-25-2010, 07:58 PM
chopper89's Avatar
Member #1634
Cool
thats were the belt is at under that cover. and to get the water out if you got some in there you will have to take it off. if you can change the oil in your car you can change a belt. its not as hard as it looks, you gotta tear half the plastics off but once you do it its no big deal. well that is if you got the tools?
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP 27 XTR TIRES
07 polaris sportsman 800 driving vibration
2009 polaris ranger vibration
polaris engine vibration
polaris ranger 500 vibration
polaris ranger 700 vibration
polaris ranger engine vibration
polaris ranger vibration problem
polaris ranger vibration problems
polaris ranger weird vibration
vibration on 2009 polaris 500 ranger
vibration problem with polaris 07 ranger
Crazy CDI/Fuse problem - can't figure it out! trickis ATV Repair and Maintenance 1 04-22-2010 06:13 AM
2006 x2 vibration in 4 low tbumd ATV Repair and Maintenance 4 02-23-2010 07:01 PM
Polaris RANGER RZR dominate Crazy Horse Goes 1, 2, 3 dascrow Polaris ATV News 0 04-02-2009 07:44 PM
