Recommended engine oil NLA through Polaris? - Polaris ATV Forum
Old 04-30-2010, 02:42 PM
jethrob's Avatar
Member #3471
OK here's the deal.
Going to change my oil.
Looked in my manual, 06 sportsman 500 HO calls for 0-40 Synthetic P/N 2871654.
Dealership sends my parts order out the door in a bag and I got PS-4 Plus 2876247.
I called Polaris, and they said the 2871654 superceded into 2876247 and was still available.
Dealer said it is NLA, and they substituted the new 2-50.
The story I got was it supercedes, and Polaris had done this with a lot of their oils. The parts coutners words were "they used to make a lot of different oils, but now they have consoldated and are just using a few. It's what we put in them and recommended, and will be OK".
I'm a little worried that Polaris has done this to cut manufacturing costs without regards to the longetivity of the machine. The manual spells out 0-40, not 2-50.
Should I go aftermarket 0-40 or put in the 2-50?
06 Sportsman 500 HO non EBS
06 Honda Recon 220
09 Coolster 125
Old 04-30-2010, 03:16 PM
Yea go 0W-40 I use Mobil-1!
Old 04-30-2010, 03:17 PM
everything you have been told is true.
IMO, you could run either the 0-40 aftermarket or the 2-50. i dont know if they have research to support the 2-50 over the 0-40, or if it was a cost thing, but they are really so close that i wouldnt worry about. just my .02 though. do what makes YOU feel better. you might be able to get 0-40 cheaper the the PS4 stuff.
hope that helps you
Old 04-30-2010, 06:10 PM
sparky's Avatar
Member #4207
That's funny cuz when I wanted to change the oil in my 09 850 xp, I read my manual which spells out 20w-50. The dealer said that was wrong, that we use 0-40. They 'suggested' I use the PS4 kit which, as he stated directly from Polaris, was 0w-40. Kinda a conflict with the manual yet sold specifically for the xp. ????
09 850 xp
GBC Spartacus tires w/ black ss212
Frt. and rear lock and ride box
Hand and thumb warmers
Frt. brushguard
HID Lighting
Old 04-30-2010, 08:16 PM
jethrob's Avatar
Member #3471
I think the manual should have read 2-50.
You would think somebody that knew what the hell one of those machines were would proof read the manual before they print ten thousand of them.
06 Honda Recon 220
09 Coolster 125
Old 04-30-2010, 08:17 PM
this has been a big debate for a long time, and i dunnot whats what anymore. the PS4+ was a 0w-40, then guys started saying polaris switched it to a 2w-50, some say the have, some say they havent, i dunno. polaris doesnt spell out the weight on the label.
whatever the PS4+ is, it is perfectly safe to use in every 4-stroke polaris motor
Old 05-01-2010, 03:45 AM
sparky's Avatar
Member #4207
IMO, its a marketing thing. They dont tell what the PS4 is. Only that is what you need. So now I cant go buy an aftermarket oil. They always got you one way or another.
09 850 xp
Frt. brushguard
HID Lighting
Old 05-01-2010, 06:32 AM
High Velocity's Avatar
Member #4251
I've been running Mobil 1 0W/40 synthetic in my 500SP for years and now I'm running Mobil 1 5W/50 in my '10 850. I've used up the case of 0W40 that I bought a couple years ago, so the next oil change on the 500, it too will be running 5W50.
best oil for polaris sportsman
engine oil for polaris 500
motor oil for 1997 polris sportsman 500
polaris 500 engine oil
polaris atv engine oil
polaris engine oil
polaris motor oil
polaris oil
polaris recommended oil
polaris sportsman recommended oil
recommended oil for polaris atv
what kind of motor oil 500 polaris
2009 Polaris 550xp engine rattle?????? therattler Polaris XP 12 08-22-2011 01:06 PM
2000 polaris scrambler 500 engine used tomy1 ATV New Members 0 03-11-2010 08:18 PM
Engine ID DaveM Polaris Sportsman 0 02-07-2010 03:08 PM
96 polaris engine upgrade/exhaust upgrade the green machine ATV Performance Modifications 1 06-30-2009 06:14 PM
Will this engine fit? Drummer89 ATV Repair and Maintenance 1 05-29-2009 08:27 AM
