04-30-2010, 04:22 PM
Member #625
Hid light kit 35w or 55w
How much brighter are the 55 watt kits with the 6000k bulbs over the 35 watt kit with the same bulbs, I'd do the swap if I could gain a little light.
04-30-2010, 04:26 PM
Member #4207
I was thinking of the 35 watt 5000k for my xp only cuz I was worried about the heat generated from the 55 watt. I would love to go with the 55 watt if I knew it wouldnt create a heat problem in the headlamp housing.
09 850 xp
GBC Spartacus tires w/ black ss212
Frt. and rear lock and ride box
Hand and thumb warmers
Frt. brushguard
HID Lighting
04-30-2010, 04:47 PM
Member #625
I read a reply awhile ago on another site about a guy running the 55watt lights in his bumper lights and the guy said he's had no problems with them at all, I was going to PM the guy but I can't remember the site I found this info on.
When I find the info I'll post it.
04-30-2010, 04:58 PM
Member #4207
I think I saw something about the same subject on this site quite awhile back. I'm hoping that somebody else has done this on their machine cuz I dont want to buy something that will cause problems later on down the road. BTW, what machine is yours?
09 850 xp
Frt. brushguard
HID Lighting
04-30-2010, 05:31 PM
Member #3684
they are much brighter. go with 55w
2012 Sunset Red XP 850 HO EPS- Everything.....
2010 Sunset Red XP 850 EPS;6000K 55W HIDS, Deluxe front and rear brush guards, 3500lb winch, heated grips and thumb, front and rear rack extenders, polaris hand guards, (2) 2gal Rotopax, Lock and Ride Gun Boot, Lock and Ride Rear Cargo Box
2009 XP 550 Browning Edition- Stock
04-30-2010, 05:36 PM
Member #4207
I wud love the extra brightness, but with the extra light comes extra heat. Thats what I'm worried about.
09 850 xp
Frt. brushguard
HID Lighting
04-30-2010, 05:50 PM
Member #4207
I've heard that the kits are based on the bulb number (mine is 886) but cant seem too find exact kit that is plug and play that every one claims. Wud like to find something that I know wud work with my machine and no problems.
09 850 xp
Frt. brushguard
HID Lighting
04-30-2010, 06:53 PM
Member #3684
ddm tuning has some kits. the 880 bulb should work. You won't have any problems with the heat. If you have a 55w regular bulb, which you do, a 55w HID bulb should burn cooler.
04-30-2010, 06:58 PM
Member #3684
Check out this thread
Headlights to HID
04-30-2010, 07:11 PM
HIDs do run cooler then regular halogen bulbs do
35/35w bulb hid for polaris atv, 55 watt headlight polaris sportsman, 55 watt hid kit in atv, are 6000k 55 watt hid lights too bright?, atv 35 55 hid, atv 35w lights, best atv light kit, can you swap kc apollo lights with hids, ddm tuning hid for polaris 800 sportsman, headlight wattage polaris sportsman, hid light 55w, hid lights atv, hid lights for atv, hid lights in north attleboro ma, hids in polaris sportsman, polaris 55w hid light, polaris atv light kits, polaris sportsman hid light problems, polaris sportsman hid lights, vvme lights polaris
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
3 light mod
Outback101 |
Polaris Sportsman |
19 |
10-08-2010 05:36 AM |
3 Light Mod
Bigriver |
Polaris Sportsman |
2 |
03-29-2010 03:33 AM |
tool light
schaf's PoPo |
ATV Repair and Maintenance |
3 |
03-16-2010 05:23 PM |
AWD light
benm |
4 |
03-12-2010 01:49 PM |
awd light ?
tlyons68 |
Polaris Sportsman |
3 |
02-07-2010 04:21 PM |
