What are codes 51 and 52 - Polaris ATV Forum
Old 05-03-2010, 09:30 AM
surfsharker's Avatar
Member #4385
2004 Sportsman 700 EFI. Was riding yesterday and the wrench came up on display..ran diagnostic and came up with codes 51 and 52. The wrench would come on as soon as was turned on but would clear itself as soon as you started moving.
Old 05-03-2010, 10:55 AM
mariano550's Avatar
Member #4459
This the error code list:
21 Loss of Synchronization
22 TPS Circuit: Open and Short To Ground
22 TPS Circuit: Short To Battery
23 RAM Error: Defective ECU
25 Transmission Input - Invalid Gear
26 Vehicle Speed Sensor - Implausible
41 Air Temp Sensor: Open or Short Circuit to Sensor Voltage (ECU)
41 Air Temp Sensor: Short Circuit to Ground
42 Engine Temperature Sensor Circuit: Short To Ground
42 Engine Temperature Sensor Circuit: Open or Short to Battery
45 Barometric Pressure Sensor: Circuit Low Input
46 Barometric Pressure Sensor: Circuit High Input
51 Injector 1: Open Load
51 Injector 1: Short Circuit to Ground
51 Injector 1: Short Circuit to Battery
52 Injector 2: Open Load
52 Injector 2: Short Circuit to Ground
52 Injector 2: Short Circuit to Battery
54 Engine Temperature Lamp: Open Load
54 Engine Temperature Lamp: Short Circuit to Ground
54 Engine Temperature Lamp: Short Circuit to Battery
55 Diagnostic Lamp: Open Load
55 Diagnostic Lamp: Short Circuit to Ground
55 Diagnostic Lamp: Short Circuit To Battery
56 Pump Relay Open Load
56 Pump Relay Short Circuit to Ground
56 Pump Relay Short Circuit to Battery
58 Cooling Fan: Open Load
58 Cooling Fan: Short Circuit to Ground
58 Cooling Fan: Short Circuit to Battery
61 End of Diagnostic
2004 polaris sportsman 700 code 51
2006 polaris code 51
2011 rzr 800 shows code 52
polaris 1k code 52
polaris 700 code 51
polaris code 51
polaris codes 51 and 52
polaris ranger 800 code 51
polaris ranger code 51
polaris ranger code 51 and 52
polaris rzr 800 code 51
rzr code 51
engine codes Nobike Polaris XP 4 10-20-2014 03:19 PM
blink codes 500x2 efi duane Polaris Sportsman 6 12-08-2009 06:08 PM
HELP - Error Codes firedog ATV New Members 1 09-24-2009 04:42 PM
