trans fluid? - Polaris ATV Forum
Old 06-12-2010, 05:13 PM
odie22's Avatar
Member #2429
trans fluid?
2000 2001 sportsman question....
i just bought some gear oil for the trans do i pour this were the dip stick is at the rear of my atv? i dont know if thats were the dif fluid goes or the trans goes. if not were does the trans fluid go.
by the way i got PURE POLARIS AGL PLUS SYNTHETIC GEARCASE AND TRANSMISSION FLUID
-odie22
Old 06-12-2010, 05:16 PM
you should have a drain plug and a fill plug, and if you fill it through the fill plug, you pour it in until it reaches the bottom of the threads/pours out the hole. what machine btw?
Old 06-12-2010, 06:32 PM
odie22's Avatar
Member #2429
man i got the atv used threw a friend and iam not really sure what year it is, how do i tell. i know its a sportsman 500 remington edition iam thinking around a 2000 2001 let me know what to look for to find out. as on the belt cover it got something like ebs control
-odie22
Old 06-12-2010, 09:14 PM
High Velocity's Avatar
Member #4251
On that machine, you do indeed fill it through the dipstick hole.
2010 850XP - My La-z-boy on steroids.
2003 SP500 - Old Faithful
Old 06-12-2010, 10:29 PM
odie22's Avatar
Member #2429
nice thanks for the info, how can i tell what year polaris i got?
one more thing please... do i have to go to polaris to get coolant or can i just go to the parts house and pick up green coolant?
-odie22
Old 06-12-2010, 11:16 PM
Razorback's Avatar
Member #4649
If it's a HO, then it's at least an 01.
Find your vin#, then count left to right 10 digits. The tenth digit is the year model.
0=2000
1=2001
etc.
If it's a letter, not a number, then count backwards using the alphabet.
z=1999
y=1998
x=1997
etc.
Your next question will probably be: "Where's the vin#?" LOL
They put them in several different places depending on model. Also, they're engraved on the metal frame (not a plate or tag) and can be very hard to see.
Look in these areas:
On the bottom frame tube on the left front. Kind of under the oil reservoir.
On the right front frame downtube under the right fender.
Under the seat.
On several models they were dumb enough to put a sticker right on top of the front plastic. Those usually didn't last too long.
They just got kinda crazy with where they put the numbers. On the 450, both the vin# and engine serial number are on the engine itself.
And yeah, on those models you've got the drain plug underneath and the dipstick on top. If you're changing the fluid, then it's one quart.
Old 06-12-2010, 11:27 PM
odie22's Avatar
Member #2429
man you guys are a big help!!! thanks for all the info, i just want to make sure i check the hole thing over befor i take it out and ride
1998 polaris sportsman 500 transmission oil
200 polaris 500 trans fluid
2001 polaris sportsman 500 transmission fluid
98 polaris transmission oil fill
98 sportsman trans fluid
how many quarts of transmission oil are in a 1999 polaris big boss 500
how much does polaris sportsman transmission fluid hold
how much transmision oil does my 1999 polaris scrambler 400 hold
what kind of transmission fluid can you use in a 97 polaris scrambler 400 4x4
what type of fluid should i use in the transmission on my 98 sportsman
what type of oil do you use in the transmission on a 1997 polaris sportsman 500
what type of transmission fluid can put in 97 polaris 400 sportsman
need trans The Kid Polaris Sportsman 0 06-01-2010 06:21 PM
trans locks up piemp ATV Repair and Maintenance 0 03-10-2010 06:35 PM
850xp trans fluid change SNW629 ATV Repair and Maintenance 3 02-14-2010 05:11 PM
01 scrambler trans ad2tude Polaris Scrambler 1 11-17-2009 01:08 PM
Trans oil what to use? macgyver ATV Repair and Maintenance 1 09-13-2009 05:52 PM
