Old 06-13-2010, 12:38 PM
odie22's Avatar
Member #2429
coolant
what type of coolant do i need for 2000 sportsman 500? i see its green can i just go pick up some green coolant from the parts house? please i need to know.. also witch way does the face need to blow? iam haveing the temp light come on. i put my had in front of the rad and it feels like its pulling air to the motor. i put my hand on the back side were the motor is and i feel air is this right.
-odie22
Old 06-13-2010, 02:28 PM
stanley's Avatar
Member #5422
I have always used the green from the auto parts store, otherwise you could buy the universal coolant you can add it to any color/make of vehicle. with temp light make sure radiator is clean remove the front screen and side covers and hose it off good. the fan should be sucking air through radiator otherwise when you are driving the fan and natural air movment would be fighting eachother
Old 06-13-2010, 03:08 PM
slyder01's Avatar
Member #3440
Polaris recommends their coolant cause it's a 60/40 mix
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
Old 06-13-2010, 03:58 PM
odie22's Avatar
Member #2429
thanks, i think i found the problem it was low on coolant and i let it run for a good 20mins and no temp light.
-odie22
2001 polaris sportsman 400 coolant change
2002 polaris sportsman 400 engine coolant
2008 polaris ranger coolant
atv polaris ranger 05 what type of coolant goes in it
changing anti freeze polaris 700
coolant type for 2008 polaris sportsman atv
polaris atv coolant
polaris coolant
polaris ranger antifreeze
polaris razor coolant change
polaris sportsman coolant
radiator and resorvoir on the 2002 700 polaris sportsman
what coolant to use for polaris 500 atv
what kind of antifreeze for polaris ranger 700
what kind of coolant to use for polaris atv
what type of antifreeze for polaris 700
what type of coolant should i use for a polaris sportsman 400
what type of coolant should i use in my polaris atv
where do you fill coolant on polaris sportsman
where do you put engine coolant in a polaris atv
Coolant buckfever5 ATV Repair and Maintenance 4 05-08-2010 10:34 AM
coolant spraying eg_runner22 Polaris Predator 7 05-08-2010 09:43 AM
08 800 coolant polarisfamily ATV Repair and Maintenance 0 04-24-2010 03:11 AM
Anyone use Engine Ice coolant before?? redneck2725 ATV Performance Modifications 8 04-08-2010 01:28 AM
Too much coolant? dodgeram3500 Around The Garage 4 01-20-2010 05:24 PM
