06-18-2010, 04:23 AM
Member #4997
New tires=new weight and clearance
Well I promised a follow up with the numbers so for those of you who are curious here they are.
Stock tires and wheels: Fronts- 24.0lbs each, Rears- 31.5lbs each.
28" Zillas and 14" SS212: 9"Fronts- 35.0lbs each, 11"Rears- 42.5lbs each.
Over all they averaged about an 11lbs difference between each tire and wheel so a total of approx. 44lbs was gained.
For the clearance I measured each side before and after.
Before:
Front- 10.25"
Left- 12.0"
Right- 11.875"
Rear- 12.75"
After:
Front- 12.5"
Left- 14.5"
Right- 14.25"
Rear- 15.75"
I think it is safe to say that approximately 2.5" of ground clearance was gained over all.
Any questions let me know. I will be happy to help!
 2010 Sportsman 800EFI
28" Zillas on 14" SS212 Blacks
RubberDownCustoms 2" Lift
3500lb Polaris Winch
Rear Rack Extender w/Moose cargo box (modified)
Better to have it and not need it, than to need it and not have it.
06-18-2010, 04:31 AM
Member #4866
stocks
Before:
Front- 10.25"
Left- 12.0"
Right- 11.875"
Rear- 12.75"
After:
Front- 12.5"
Left- 14.5"
Right- 14.25"
Rear- 15.75"
what size were the stock tires???
2010 850 XP EPS Stealth Black
from dealer
2500lb. winch (with wireless remote)____60" Glacier® II Plow System with extras___Lock & Ride® Front Cargo Box____Rear Rack Extender___Moose hand and throttle warmers
HID Plug and Play Light Kit for 550/850(www.theatvsuperstore.com) lower lights tinted with 20% window tint (still brighter than stock but not blinding bright)
Front & Rear A-Arm Guards XP550/850 2010(www.theatvsuperstore.com)
28" zillas on stock 14" rims(http://www.4wheelparts.com)_____26" stock tires on itp ss212 14" thanks SNW629
Deluxe Front/Rear Brushguard(http://www.superatv.com/)
3 in 1 Polaris atv hitch from (www.theatvsuperstore.com) might i add it was a gift they sent me just for buying some stuff
Galls® 100W Remote Siren (http://www.galls.com/)
lots of lights
motor cycle radio
(still to come Wes Standard(rear seat and storage), dalton clutch kit, 2 inch lift, stealth snorkel kit if they ever make them for the 2010 )
06-18-2010, 04:37 AM
Member #4997
Stocks: Fronts- 25x8x12 Rears- 25x11x12 Carlisle 489's. Wheels are 12" stock polaris wheels (stamped aluminum? steel?)
06-18-2010, 04:55 AM
Member #2758
Before:
Front- 10.25"
Left- 12.0"
Right- 11.875"
Rear- 12.75"
After:
Front- 12.5"
Left- 14.5"
Right- 14.25"
Rear- 15.75"
Where were you measuring from and to ?
06-18-2010, 05:07 AM
Member #4997
I didn't get under the machine and measure the actual frame. I measured the front from the lowest point just below the radiator, the sides from the center of the floorboards, and the rear at the lowest point below the hitch. The only lower points other than these I think would be under the floorboards. The front and rear should be pretty close to actual.
07-13-2010, 07:22 PM
Member #5957
Does the front end pop up in deep water?
07-14-2010, 12:32 PM
Member #4997
To be honest brother, I'm not willing to ride in water deep enough to find out. I have been in water maybe to the top of the tire and I would say that there is no floatation trying to happen. I wasn't trying to get them to float either though. It may.
07-14-2010, 02:05 PM
Member #5957
I understand, I wouldnt take a new 800 deep either. My old 500 sure does get used though. I am trying to find the best way to pop the front end up in water. I am putting 28s on it soon and hopefully in low and with me way back on the seat itll do it
07-14-2010, 03:07 PM
Member #858
Bigger Tires mean High Clutch RPM's...
Good clearance...i have 26 inch zillas and 14 inch wheels 108's SS on my Ho with a 2 inch lift all around i have about the same clearance as you...but there is a 2 inch difference because of the skid plates underneath. FtoR ..but measuring from the ground to my fenders its only a 1/2 difference..either way its a 3 inch gained after all...As For floating the frontend....My Ho will start to float in 3.5 feet of water...with the Zillas on...As for 28 inch 14 zillas big gain in weight you will feel a higher RPM till your clutch kicks in and you'll lose holeshot lift...you'd be smart to put a better clutch.cause you'll lose belt life, more strain on axles...thats why i went to 26 inch and nothing bigger and i honestly did'nt lose any power...Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
2010 sportsman 800 tires, atv flotation skid plates polaris sportsman, do all 4 tires need weights, how much do 14 ss212 weigh, how much do stock tires weigh polaris sportsman, how much does a polaris rim and tire weigh, how much does the 2010 two-up polaris atv weight, how much does the stock polaris wheel weigh, itp rims ss212.weight, itp ss212 weight, polaris 14 wheel weight, ss212 weight, ss212 wieght, what do itp ss 212's weigh, what is weight of atv in water.
