06-24-2010, 07:58 AM
Member #5588
08 800 sportsman pressure in fuel tank
the fuel tank on my 800 becomes pressurized after a riding for awhile. im thinking it might be a plugged vent. any ideas.
06-24-2010, 11:12 AM
Member #5297
It shouldnt be pressurized after riding. Since you are taking fuel out of the tank it would be creating a vacuum in the tank if it was plugged. If that's the case the vent is defiantly plugged.
06-24-2010, 11:22 AM
Welcome to the boards!
06-26-2010, 05:33 AM
Member #1958
uhhh with 4 gallons of gas sittin on top of a 400 degree stove being shaken like a paint mixer I'd be suprised if it didn't boil and build pressure. There's a vent tube running up into the pod that will bubble off the pressure. You can hear it and see it when ya stop if you look up next to the steering stem and you'll get some overflow too if you top up too full when it's already hot. Just crack the lid when you stop to let the pressure off and it'll be fine.
06-28-2010, 03:21 AM
Member #5588
Had the machine apart this weekend ,all the plastic off, replaced a couple of wheel bearings. I found that the vent tube for the gas tank was kinked so it was not venting straightened it all out hope this does it. Thanks all the responses.
02-28-2011, 05:01 AM
Member #11301
Hey Markiedog..did you find the problem ..mines doing the same thing..thanks
02-28-2011, 06:56 AM
Member #5588
Yes found that the vent tube to the head light pod was kinked straightened that out and wrapped the tank with heat reflecting foil tape. no more problems hope this helps.
02-28-2011, 10:29 AM
Member #11301
THANKS I will try that..I did see there was no wrap on tank...didnt notice the hose but will look
2005 polaris fuel tank pressure, 2005 polaris sportsman 800 gas boils, atv gas tank pressure, atv gas tant vent, boiling fuel in a 700 polaris, fuel press on 05 sportsman 800, fuel pump specs sportsman, polaris 500 sportsman fuel tank, polaris 800 fuel tank pressure, polaris 800 fuel vent tube, polaris fuel runs out fuel tank vent hose, polaris fuel tank overflow, polaris sportsman 800 fuel pressure, polaris sportsman 800 fuel tank, polaris sportsman 800 fuel vent, polaris sportsman 800 gas tank, polaris sportsman gas tank, polaris sportsman gas tank foil, polaris sportsman high fuel pressure, sportsman 800 fuel pressure
