500 HO overheating - Polaris ATV Forum
post #1 of 14 (permalink) Old 06-26-2010, 09:10 AM Thread Starter
02f250fx4's Avatar
500 HO overheating
Sorry, if this has been covered, I am new to the forums and tried searching the existing posts with no luck.
I have a 05 500 sportsman HO. The fan turns on and off properly, I think the coolant is flowing properly due to movement of the fluid in the reservoir. The motor does not seem any hotter than normal, but the display flashes HOT engine. Can anyone point me in the right direction?
02f250fx4 is offline
post #2 of 14 (permalink) Old 06-26-2010, 09:30 AM
brody81's Avatar
Take a good look at the front of your radiator. Make sure its clear of dried mud. If the "fins" that make up the radiator are clogged they will not be able to dissipate heat properly. Ive had this happen to me shortly after purchasing my quad after the first good mudding trip.
09 550 XP Stealth Black "or covered with mud"
"buy it to ride it"
brody81 is offline
post #3 of 14 (permalink) Old 06-26-2010, 09:43 AM Thread Starter
02f250fx4's Avatar
I cleaned the radiator fins out this morning, because it was a little dirty. It didn't help. I topped the coolant off to. This seemed to make it where I could ride the bike a little longer before the display warning came on. I think it may be a faulty sensor but I am not sure. I don't want to ride it in case I am wrong.
post #4 of 14 (permalink) Old 06-27-2010, 10:46 AM
gator's Avatar
get a temp. sensoring gun and check temps at all heat sensors, radiator at intake and outputand at engine, that should tell u what is goin on!!!!!!!!
gator is offline
post #5 of 14 (permalink) Old 06-27-2010, 10:49 AM
gator's Avatar
and check the thermostat too.
gator is offline
post #6 of 14 (permalink) Old 06-27-2010, 12:39 PM Thread Starter
02f250fx4's Avatar
what temps should I be looking for as acceptable and unacceptable?
post #7 of 14 (permalink) Old 09-12-2010, 05:58 PM
bwill2320's Avatar
I have a Polaris 450 Outlaw and the same thing happens to me as well. I have cleaned the radiator until is sterile and still the temp light turns on after a while of riding. Anyone know where to starting looking for a solution?
bwill2320 is offline
post #8 of 14 (permalink) Old 09-12-2010, 06:20 PM
scottdeet's Avatar
rear side of fan also.
Take a good look at the rear of the fan and inside the shroud also.
The one I'm working on now looks spotless from the outside, but upon crawling around underneath I noticed this.
Take care,
Scott Deeter
scottdeet is offline
post #9 of 14 (permalink) Old 09-14-2010, 12:43 PM
MUDDIE49's Avatar
Sounds like you have a faulty sensor....if the quads not overheating then you can rule out the thermostat unless its just opening enought to let some coolant pass...500's run about 180 to 190 degrees before the fan comes on and will cool down to normal 150 to 160 degrees..is the oveflow bubbling? Are you loosing any coolant? That radiator looks beat...if fins are clogged or bent up you won't get the proper air threw the rad to cool the quad..and that maybe throwing your light on....bad circulation..Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
MUDDIE49 is offline
post #10 of 14 (permalink) Old 09-14-2010, 04:41 PM
weedy's Avatar
Most common reaSON FOR OVER HEating is a dirty radiator. It takes a very detailed cleaning to get the proper amount of air flow to prevent over heating.
2005 SP 500
2004 SP 500
2002 SP 500-SOLD
2001 SP 500-TOTALED
weedy is offline
overheating? atomicstew Polaris Scrambler 12 10-27-2014 02:01 PM
Overheating 700 bbbj ATV Repair and Maintenance 7 07-13-2014 01:59 PM
03 700 overheating mudbug Polaris Sportsman 9 06-30-2010 05:32 PM
Overheating 700 bbbj ATV General Discussion 11 02-13-2010 10:10 AM
'01 500 HO overheating knute13 Polaris Sportsman 5 06-27-2009 08:27 AM
