06-28-2010, 08:26 AM
Member #5585
CV boot replacement
I have a 2007 Sportsman 500 that needs a new CV boot on the front wheel side. I ordered a kit from the dealer, but was wondering how to do it? Any special tools needed? Thanks, Mike
06-29-2010, 09:41 PM
Member #5616
I did one on mine last summer. The only special tool would be the one that tightens/installs the CV boot clamp. Quite expensive. I screwed the Polaris clamp up cuz I'm too cheap to by the tool (did I say EXPENSIVE), so I just went to NAPA and got the clamp for a Honda front wheel drive car ($3) and put it on with needle nose pliers.
Cut the clamps an boots off and the cv's will pop off with a rubber mallot or a slide hamer. There is a circlip in the joint that will spread and allow the shaft to come out. I found a video on Youtube-Going 4WD-Replacing a Broken CV Joint Boot. I couldn't get a link to work for this post. But I Googled the title and it came up.
06-30-2010, 08:59 AM
Member #5585
Thanks Offroadster, that's what I was looking for, I think I'll try the pliers as well, rather than buy the tool.
07-01-2010, 03:23 AM
Member #2255
I managed them clamps with a good pair of channel locks.Took a good squeeze.
2010 Sportsman 500 HO
Orange Madness
2001 Suzuki King Quad 300
2002 Suzuki King Quad
07-02-2010, 06:32 PM
Member #5193
You're right. You can work those clamps on if you are lucky or persistant. I think I did mine with channel locks too. Took a couple trys but got them on. Overall the boot replacement is pretty easy. I took the shaft off, held it by both ends and pushed the shafts together to expand the circlip then pulled apart quick. It came right apart.
1996 polaris sportsman 500 front cv boot replacement, 1996 polaris400 sportsman front drive boots, 2000 polaris sportsman 500 4 wheel drive rear inner cv boot, 2004 polaris sportsman 400 cv boot, cv boot replacement for polaris 500, cvc boot polaris 500 sportsman replacement, polaris atv cv boot replacement, polaris atv forum boot replace, polaris boot replacement, polaris cv boot replacement, polaris cv joint replacement, polaris cv replacement, polaris ranger front wheel cv boot replacement, polaris sportsman 400 cv boot fix, polaris sportsman 400 joint repair, polaris sportsman 500 cv boot replacement, polaris sportsman cv boot replacement, repair cv boot sportsman with funnel, replace cv joint boot polaris ranger 500 2002, u tube how to repair boot on polaris 400
