  #81 (permalink)
Old 09-12-2011, 11:33 AM
justinmiller930's Avatar
Member #16605
Send a message via ICQ to justinmiller930
I just purchased a set and am waiting for them to arrive. They should be here today or tomorrow.
Will keep everyone updated on the status.
I ordered a set of the 6000K 35 Watt blubs.
Hope they're plug-and-play as everyone says. I installed a set of HID's in one of my vehicles and liked them, but couldn't remember how difficult it was to install.
  #82 (permalink)
Old 09-12-2011, 03:02 PM
If you got them from my store then yes. If not then ?
  #83 (permalink)
Old 09-13-2011, 04:51 AM
Member #16605
No, Thor, I did not. I bought a kit from Ebay. If it doesn't work, i'll send it back and will def. order from your store. I received my package yesterday and will attempt to install today or tomorrow. Will keep everyone updated.
  #84 (permalink)
Old 09-14-2011, 03:17 AM
Member #16605
Unfortunately, and as I'm sure is my luck, the kit I ordered didn't work. Most of the kit was plug and play, but there were two wires that were just hanging there with metal ends on them. They definitely didn't work for my application. I will be purchasing from The ATV Store.
  #85 (permalink)
Old 09-14-2011, 03:57 AM
Remember we test what we sell and only sell the best! I guarantee our kits are true plug and play. They are so easy to install Grandma can do it! If you order by noon they usually ship same day.
Sportsman XP Kit ATV HID Lights
Sportsman Classic Kit ATV HID Lights
RZR Kit WOW! You found them here at TheATVSuperStore.com!
  #86 (permalink)
Old 09-14-2011, 05:34 AM
Member #16605
Will the Sportsman classic kit fit a 2008 Sportsman 400? I don't have the light on the handlebars though.
  #87 (permalink)
Old 10-13-2011, 04:50 PM
captsloan's Avatar
Member #11210
Thor, HID question
I want to order from you the HID kit for my 2006 500 sportsman:
1)I want the most light possible as I ride the jungle in Costa Rica, I saw someone said the 55w will not cause a melt down, please tell me which kit I need for all 3 lights and is 55w ok?
2) I put a mod that uses a diode so I have all 3 light on when on high, can I leave this or will it be too much draw from the high beam side? should I get a different mod for this?
Thank you
  #88 (permalink)
Old 10-13-2011, 05:40 PM
2001sportsman400's Avatar
Member #8639
Does anyone make a kit for the older sportsmans yet? I have a 2001 sportsman. Thanks
  #89 (permalink)
Old 01-26-2012, 08:40 AM
ZaM's Avatar
ZaM ZaM is offline
Member #22321
interesting thread. learned a lot from you guys. thanks!
general motors headlights
  #90 (permalink)
Old 04-06-2012, 06:26 AM
STEALTHZILLA's Avatar
Member #24814
I just placed a order from Thor on the 6k thin ballast kit.. How do these hold up in deep water or getting wet? From what I read,the following was addressed..Fitment,bulb size,and ballast placement..Has anyone had any issues from them being momentarily submerged in h2o? Thanks,Marcus
3" Arched A-Arm Catvos lift
31" Outlaws on 14" No-Limit Octane's
Guru front & rear bumpers
Infinity 800watt Sound System
HMF Swamp Series Exhaust
Clutch Kit
Hi-Lifter Hi-Flo Relocated Radiator
Snorkled and extended vent lines
Rhino axels on all 4 corners
Thors HID's
Smoked Rear Tail-lights
on my 09 850XP w/EPS
09 polaris 850 xp headlight bulb size
2006 polaris ranger headlight socket
2008 polaris ranger bulb number for hid kit
atv guru and polarisatvforum
blue xenon headlight bulb polaris
hid kit for 03 polaris
hid lights hold up on atv
how many bulbs does a 2006 polaris 800 headlight system have
polaris 2876464
polaris hid kit
polaris ranger headlight bulb size
polaris ranger hid bulb type
polaris sportsman 800 hid kit
polaris sportsman 850 xp headlight bulb size
polaris sportsman hid kit
polaris sportsman hid lights
ranger 800xp hid kit
replacement headlights polaris ranger 2006 500
sportsman 550 ballast mount
big bore kits? Raimey ATV Performance Modifications 6 09-05-2010 05:49 PM
clutch kits gator ATV Performance Modifications 5 05-11-2010 12:30 PM
clutch kits gator ATV Performance Modifications 1 05-03-2010 08:07 AM
lift kits???? lsxmike ATV Brakes & Suspension 4 03-20-2010 03:57 AM
Cam Kits WLong2485 ATV Performance Modifications 2 07-20-2009 07:01 AM
