96 Xpress Carb ?'s...Where do these hoses go? - Polaris ATV Forum
Old 07-17-2010, 06:59 AM
barker23's Avatar
Member #6001
My carb started flooding out and I ended up with gas in my pull start housing. A co-rider told me my float was pry stuck open so Ive removed the carb. The questions I have is 1. Is the gas in the casing caused from the float sticking? and 2. Does anyone know where the 2 small brown hoses attach? (the 2 hoses that come together were melted to the muffler, and the other has just a cut end going nowhere. Are they gas hoses, oil hoses, vent hoses?
Thanks for any advice.
Old 07-17-2010, 07:52 AM
tt425's Avatar
Member #3687
I am not to familiar with that atv but my guess would be that they are vent hoses. The ethanol in the gas is causing problems with small engines and atv's. After you clean the carb if the gas is not fresh replace it and add a fuel treatment such as Seafoam(#SF16) or similiar it only takes about 1oz per gal and I use it in all my atv's,lawnmower, and generator. It works.
Old 07-17-2010, 08:11 AM
barker23's Avatar
Member #6001
The gas is fresh, had just filled it up couple days ago. Im wondering now, after reading some other post, if the hoses arent oil injection and overflow hoses, just figuring out where they go....
1996 polaris 300 xplorer carbrator hook up
1997 polaris 300 fuel line pics
96 polaris 300 express carberator hose diagram
96 polaris xplorer 300 carb. with hoses connected pic
96 polaris xpress 300 carburetor fuel line routing
gas lines in a 1996 polaris xplorer carburetor
pictures of polaris 400 xpress carborator s
polaris 300 explorer carb hose diagram
polaris carburetor hose hook up on a 1996 xpress atv
where does the oil hose hook up to the carburetor for a 1996 polaris xplorer 300
xpress carburetor vent tubing
97 Xpress 300 - What is the correct gas/oil ratio? Nandy Polaris Sportsman 8 09-07-2010 12:47 PM
96 xplorer 400 carb hoses 96xplorer400 ATV Repair and Maintenance 4 07-23-2010 08:05 PM
1995 trail boss with dry rotted vent hoses new2polaris ATV New Members 11 05-27-2010 09:09 PM
96 Xpress Brakes turmanator ATV Brakes & Suspension 3 05-24-2010 01:55 AM
carb hoses question Southern Gent ATV Repair and Maintenance 0 05-19-2010 05:16 PM
