2000 Clutch Belt Replacement - Polaris ATV Forum
Old 07-20-2010, 10:53 AM
emike10's Avatar
Member #4064
Question 2000 Clutch Belt Replacement
My 2000 creeps forward in gear and reverse. Everything that I have read here on the forums suggest that it is a worn clutch belt. Does anyone have instructions or "How To" directions on how to get to the belt and replace it??
Thanks in advance..
Old 07-20-2010, 06:41 PM
bigman223's Avatar
Member #6055
i have the same problem. and i have just put a new belt on and it does the same jumping i think that it might be due to a high idle try decreasing the idle.
Old 08-07-2010, 02:10 AM
Razorback's Avatar
Member #4649
Remove the footwell
Loosen the vent hose
Remove the screws on the cover and remove the cover.
Take the top of the belt and work a bit of it over the secondary clutch. (Make sure it's in neutral)
Rotate the clutch backwards (clockwise) until it comes off.
Put new belt around primary clutch and start it on the top of the secondary clutch.
Rotate again in the same direction unti it pops into the clutch.
Replace cover, vent hose and footwell.
Your idling rpms might also be a little too high and causing the clutch to engage when it shouldn't.
Old 02-21-2011, 05:29 PM
craigsadams's Avatar
Member #9881
My clutch belt is rubbing against the plastic clutch cover, any ideas on how to fix this problem? the Polaris I have is a 2000, 400 scrambler, two stroke.
Old 02-22-2011, 08:00 AM
cwlongshot's Avatar
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
Old 02-22-2011, 08:49 PM
Member #9881
I've seen this video, but the primary clutch is rubbing on the back part of the clutch case. How do I fix this new problem?
Old 02-22-2011, 09:33 PM
3 Polaris Atvs's Avatar
Member #1102
I find this happens when you get stuck or pull some one else out who is stuck. The cover gets melted and rubs. Time for a new cover.
1998 Scrambler 500 HO 4x4
1995 Scrambler 400 4x4
2000 Trailblazer 250 2x4
Sportsman 90 (for my Granddaughter)
1998 Sportsman 500 4x4
Old 02-23-2011, 05:17 AM
Razorback's Avatar
Member #4649
The usual causes for this are wrong belt, bad belt, broken motor mount, mis-aligned clutches, or broken parts in the clutches.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
1995 polaris 300 tighten drive belt
2000 polaris scrambler 250 clutch
changing the drive belt on a polaris 250 atv
how to change belt polaris 90
how to replace belt on 98 polaris 250
how to replace drive belt on 2000 polaris sportsman 500
how toremove clutch from 2000 polaris 500
howv to put a clutch belt on a polaris sportsman 500
i changed the belt on my 2006 sportsman and it creeps forward
polaris sportsman 500 belt replacement
polaris sportsman belt replacement
video of changing starter on 2000 polaris trailblazer
Belt replacement jbjohnston5 ATV Repair and Maintenance 1 07-05-2010 04:34 PM
replacement belt xfactor Polaris Sportsman 16 06-28-2010 12:01 PM
2000 250 Trailblazer - Clutch / Belt Issue ? adenton79 ATV Repair and Maintenance 7 06-03-2010 06:46 PM
starter replacement / clutch bomberboat ATV Repair and Maintenance 12 03-07-2010 08:30 AM
'05 700 will not go into Hi gear after belt replacement. gandgracing Polaris Sportsman 8 09-10-2009 04:23 AM
