Speedometer Help - Polaris ATV Forum
Old 08-07-2010, 10:52 PM
Scott500's Avatar
Member #6389
Speedometer Help
My speedometer in my '00 Sportsman 500 has quit working on me, and I am not sure how to go about pin pointing the problem. Are these speedometer electrical or mechanical? I noticed it had quit working after I washed the ATV, so that may be a contributing factor...
Any insight would be greatly appreaciated.
Old 08-08-2010, 07:27 PM
thepopeis1's Avatar
Member #2334
those speedometers are known to go bad. let me ask you a question does your 4x4 work? the 4x4 runs through the speedometer and if the speedometer is truly not working the 4x4 is usually not working either . I'm not saying thats it for sure it could be a bad sensor or a bad wire connection.
I just replaced mine on my 99 xplorer (same part #) I bought mine from DirtCheapATVParts.com best price hands down. I looked for a long time. and evan bought a bad replacement (manufacturer date was in 2002) but when I bought this last one it was made in july of 2010. works great.
o ya I should add that yes they electrical (not cable driven)
part # is 3280363
the same speedometer fits all of thease
# 00-02 sportsman 6x6, 99-02 sportsman 500, 01-02 sportsman 400,
# 99-01 magnum 500, 00 sportsman 335, 99-00 xplorer 400.
2010 Sportsman 550XP
1999 Xplorer 400
Old 08-08-2010, 08:46 PM
Scott500's Avatar
Member #6389
Thanks man, I'll check out a replacement. Part # 3280363 isn't showing up on dirtcheapatvparts.
4X4 works good...
Old 08-08-2010, 09:23 PM
thepopeis1's Avatar
Member #2334
4X4 works good...
I think it shows up as a different part # but the one u get is that one I said. hear it is (its #1)
DIRT CHEAP ATV PARTS' 2000 Polaris ATV SPORTSMAN 500 (A00CH50AK) (MEDIUM YELLOW) Parts List
its very possible that its your speed sensor I would hate for u to buy the wrong part because of me
hopefully some one else will chime in with more help
I would at least unplug the speedometer and see if any of the connections are bad like corrosion. you may also want to try and figure out witch wires go to the sensor and use a ohm meter and see if it changes as u speed up (might want to use a jack to pick up the back wheels and be ready on that break. and have a friend check for ohms)
I wish I could help you more. but I will try to help u the best I can
ps don't try to take the speedometer apart (unless u got nothing to loose) I tryed to fix mine and I ended up breaking it more.
1999 Xplorer 400
Old 08-08-2010, 11:30 PM
Scott500's Avatar
Member #6389
Cool. I really appreciate everything.
I will poke around and see what I find. I have a big tech manual for it, but it hasn't shed much light on the matter.
Old 08-15-2010, 11:51 AM
LMAC's Avatar
Member #1519
The speedometer controls the reverse speed limiter also and when the fan comes on will kill the engine and wont start till fan goes off and also makes it hard to start
Old 08-15-2010, 07:16 PM
Scott500's Avatar
Member #6389
I'm not experiencing those problems thankfully.
I have replaced the fan though. It a newer style OEM fan. Would that have dispruted anything?
2000 Sportsman 500
Warn Winch
FMF Exhaust
OX CV Guards
Goodyear Rawhides
2000 polaris sportsman 335 speedometer
3280363 polaris
3280363 polaris speedometer
3280363 spedometer test
how to repair a speedometer on a polaris sportsman
how to replace speedo cable 1998 polaris atv xplorer
polaris 3280363
polaris 500 magnum speedomiter
polaris magnum 500 speedometer not working
polaris speedometer repair
utube 1999 polaris 500 sportsman change speedometer cable
why csan cause my king quad 400 speedometer not to work
speedometer cable for 350 4X2 dragon71 ATV Repair and Maintenance 2 04-29-2010 01:01 PM
magnum speedometer bandit ATV Repair and Maintenance 2 04-21-2010 12:49 PM
2000 Speedometer PwrBoatFan Polaris Sportsman 2 04-09-2010 08:05 AM
Speedometer Cable rmckenna Polaris Sportsman 3 03-23-2010 10:55 AM
want to buy speedometer al sportsman ATVs For Sale 1 02-05-2010 09:54 PM
