Front/ rear driveshaft removal - Polaris ATV Forum
Old 08-08-2010, 05:23 PM
ffmike's Avatar
Member #428
I'm in the early stages of replacing my u joints on my 2003 sportsman 700. I have a few questions I cant seem to find the answers too.
I have the front drive shaft off, but cant remove it from the machine. It's hitting the bottom of the motor. Do I need to unbolt the motor so I can lift it up a little so the shaft clears?
The rear shaft is loose. I can slide it back and forth. Do I have to unbolt the rear diff in order to pull it out or is there a trick?
My machine has a build date of 06/06/02. According to the Polaris web site, the front and rear u joints are different. Can anyone confirm this. I was hoping to go to NAPA and get 4 of the same u joints #338
Old 08-08-2010, 05:55 PM
MUDDIE49's Avatar
Member #858
I've heard their a pain in the butt..and from what i'm told you may have to un bolt just enough to clear the shaft ..also check your shaft in the rear for any roll pins...then it should just slide out...Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
Old 10-20-2014, 03:23 PM
Verpollropwe's Avatar
Member #47272
What I*read*I really liked it.*Thank you for*your information!
dubli
2008 polaris 800 4x4 drive shaft removal pics of
2008 polaris ranger front drive shaft removal
2014 polairs ranger 800 mid size front axel change out
best way to remove frozen yoke polaris ranger
driveshaft removal 800 crew ranger you tube
how do you take a drive shaft out of a polaris sportsman
how to get front drive shaft out of polaris ranger
how to remove drive shaft from polaris ranger
how to take a drive shaft off a polairs ranger
how to take drive shaft off of the front diff on a 2008 polaris ranger 700
polaris ranger how to remove front drive shaft
removing drive shaft on 2011 polaris ranger 800
magnum front propshaft removal rubio07 ATV Repair and Maintenance 4 01-01-2015 08:54 AM
Upgrade 96-98 Sportsman rear driveshaft island-rider ATV General Discussion 1 11-10-2009 03:16 PM
HELP 03 Ranger Rear Axle removal Airpig95 ATV Repair and Maintenance 1 10-25-2009 06:01 PM
Rear bearing removal bulldog101504 Polaris Sportsman 4 09-02-2009 08:13 PM
98 500 sportsman front driveshaft issues. Wuzzy Polaris Sportsman 2 08-26-2009 09:27 AM
