Old 08-11-2010, 06:59 PM
msadler822's Avatar
Member #6478
Does my 2010 800efi suck? Clutch clicking noise.
I bought a 2010 800 for dirt cheap the other day and I'm not too happy. I've tried searching for other posts by people who have 800's, but I'm not seeing alot. My 800 makes a clicking noise in the clutch housing (on right side)when idling and a clunk noise when slowing down. The dealer's former service manager (now a salesman) told me this was the clutch - actually the cog catching up to the chain. I hopped on a different 800 at the dealer and it did the same thing. Does this make sense? My other ATV is a Grizzly - and I've never heard anything like this. I'm kinda worried about it. Should I be?
2010 Polaris Sportsman 800 EFI Sage Green
2007 Yamaha Grizzly 700 Outdoorsman Edition
Old 08-12-2010, 03:00 AM
racer37l's Avatar
Member #5629
I'm going to take a stab at this. I looked at a pic of the clutch and like I thought, it's belt driven. So, first,I don't think the person you talked to at the dealer knows what their talking about, and the chances that two bikes at the same dealer having the same problem(well I guess it could happen). There are shims that are in the clutch to align the primary and secondary. If you take your bike to another dealer, listen for them so say the dlutch is out of adjustment. Hope this helps and good luck
Con
Old 08-12-2010, 05:29 AM
pat's Avatar
pat pat is offline
Member #6416
i have an 09 sportsmen 800 efi and i wondered the same thing. it has been ticking and or clicking since day one. the owner of the dealership said they all sound like this and other people told me that most polaris' sound like this as well. kinda like a rod knock or something
Old 08-12-2010, 10:41 AM
msadler822's Avatar
Member #6478
Lemon???
Man. I hope I didn't buy a lemon. Both 800's I rode at the dealership did the exact same thing, so I thought it was normal. Gonna call the dealer again and bring it in. Thanks!
Old 08-12-2010, 03:56 PM
msadler822's Avatar
Member #6478
Answer???
So I called the dealership and spoke to the actual service manager. He said that the clicking/clunking sound I am hearing is more than likely not the clutch (like the saleman told me) but rather the sound of one of the tranny chains "slapping" the drain plug. He says the 800's have a very loose tranny chain set up and that when you pull the drain plug you can actually see the marks that the chain from the tranny has made. He recommended that I bring it by and let him personally take a look at it - but if that is the sound I am hearing there is nothing he can do - just a noisy Polaris I guess.
Old 08-12-2010, 04:04 PM
moxie1884's Avatar
Member #2830
Send a message via AIM to moxie1884
I have the same problem with my 2010 800. when I slow down it sounds like the it's coming a part with the clunking and clanking. It goes into the shop for it's 1st maintenance warranty work on the 21st and I'm telling them to fix the problem to my satisfaction, not theirs or Polaris's.
Terry
2010 Polaris Sportsman XP 550
Director of Mass ATV Assoc.
Member of: Acadia Area ATV'ers, Hancock Cty, ME
Member of: Pathfinders
Old 08-12-2010, 04:25 PM
msadler822's Avatar
Member #6478
Good luck. Please let me know the outcome. The local guy here says he's replaced entire trannys with no improvements. Just specific to the 800's and some other models.
Old 08-12-2010, 04:57 PM
nuclear orange peel's Avatar
Member #6331
I have a 09 800 with 46 miles on it that does the same type of noise when you decel or let off the gas there is a knocking type noise, goes away if you tip into the thottlle or stop engine is quite at idle ..
I have read other threads about this I haven't heard if there is a fix...
please keep us informed
thanks
Old 08-13-2010, 02:40 PM
OldBones's Avatar
Member #5004
I have a 2010 800 that does the samething when you decel. I also asked and I was told that this is normal. I changed my oil at 50 miles and 100 hours to make sure I had all the shavings out of the oil from a new brk-in. I know, Over kill but it gave me time to learn about the machine and give it a good going over. Anyway, no marks on my oil plug so someone was wrong. I was told that the "Clunk" is a common sound when you are slowing down or first starting to go. It will be interesting to hear what you find out. Blueline or one of the others might know more ????
2010 Sportsman 800 EFI Stock
Front and Rear Brush
Moose County Plow
2005 Sportsman 500 H.O.
Moose 5 ft Plow
Old 08-13-2010, 07:19 PM
Bluemustang77's Avatar
Member #5738
My dad's 08 sportsman touring 800 has a clunking noise when he slows down.. nothing very major, a lot of the older polaris' made that type of noise. But his also has a rattle in the front... we think its just a heat shield/ some type of shield loose...
I know that my new 850 does not have much if any of the noise that the 800s or the older polaris' have.
Their ATVs are awesome.. just wish the older ones were more quiet.
2010 Sportsman 850 XP EPS Sunset RED
3000 lb Viper Max Winch w/ synthetic rope
Front/Rear bumpers
Rear Cargo Box w/ backrest and bags
Fog lights
Heated grips/thumb
K&N Airfilter
27" ITP Mudlite XTRs being delivered soon!
1700 miles now and loved every one
2010 rzr clutch rattling
2011 polaris sportsman 800 efi has a clicking noise when driving slow
can am atv clutch clicking noise
clicking clutch atv
clicking noise on sportsman 800
my polaris 800 xp has alot of slack in rear differential
noise slowing down rzr
polaris 550 xp clicking in clutch housing during
polaris 800 efi engine knock
polaris 800 sportsman clunking noise
polaris rzr clutch noise
polaris rzr idle air click noise
polaris sportsman 800 clicking noise
rod knock 2005 sportsman 700 efi
rzr clutch knocking
rzr clutch noise
rzr rod knock
should polaris rzr make clicking noise in motor
which clutch is best for my sportsman 800
yamaha grizzly 700 clunking
'09 sportsman 500 clicking noise cdwladr ATV Repair and Maintenance 3 04-30-2012 04:17 PM
2007 Sportsman - Clicking noise in clutch bjj1805 ATV New Members 9 08-12-2010 03:05 AM
09 850xp clicking noise? Breakineven ATV Repair and Maintenance 1 08-02-2010 07:18 AM
clicking noise when speeding up and slowing down Viper Polaris XP 2 07-25-2010 05:27 PM
Sportsman 800efi engine noise MudslingingSooner ATV Repair and Maintenance 0 04-09-2010 06:39 PM
