your boot
I have a 04 500HO and i just changed my boot, if its the outer u dont need to pull the shaft rite out, i cut the boot off then i cleaned the grease out of the cv, when you clean the grease out there is a clip around the shaft, squeeze it together and tap the cv off the end with a rubber hammer or pull it off by hand if you can, clean,regrease, slide the boot on then squeeze clip and slide cv back on, secure boot and ur done!
