Old 09-02-2010, 08:56 PM
peterman's Avatar
Member #6960
Question starter bendix
is there any differnec in the bendix from 2000-2001 for the sportsman 500 HO
Old 09-02-2010, 09:36 PM
nope, there is not...
welcome by the way
Old 09-02-2010, 09:57 PM
peterman's Avatar
Member #6960
do u know if you are suppose to put any oil or any thing in the recoil and fly wheel cover
thank to
Old 09-02-2010, 10:09 PM
peterman's Avatar
Member #6960
thanks for the info but i have anther ? im i supose to put any oil in my pull start and fly wheel cover it looks like there is a drain on the bottom and a spot to add on the top?
Old 09-03-2010, 05:10 AM
no, the drain is there go get fluid out if it gets in. you want it to stay dry in there. there is a seal on the otherside that sometimes oil or oil/gas gets in there, again, you dont want that.
Old 09-16-2010, 09:24 PM
46moo's Avatar
Member #6994
So blue, if the rope won't recoil, is it safe to assume it's fairly gummed up in there? Previous owner did quite a bit of riding on sand around the Platte river, so I'm guessing that's the issue. Any way you can "blast" it out without pulling the whole thing apart?
2004 polaris sportsman bendix
bendix polaris
how to replace a bendix 2004 polaris 600
polaris 500 sportsman bendix
polaris 800 bendix replacement forum
polaris bendix
polaris bindex wheel
polaris sportsman 700 bendix replacement
polaris sportsman starter bendix
polaris sportsman starter drive assembly replacement
polaris starter bendix
rebuild polaris starter
replacing bendix on sportsman 500
replacing polaris sportsman starter drive
rzr bendix assembly problems
starter bendex removal polaris sportsman 500
starter bendix assembly sportsman 700
starter bendix rebuild
starter for a polaras atv 550
bendix and starter issues tim63 Polaris Sportsman 10 04-11-2010 06:19 PM
problems with starter bendix kawastang ATV Repair and Maintenance 1 01-23-2010 07:22 PM
starter drive /bendix bomberboat ATV Repair and Maintenance 0 01-20-2010 07:18 PM
Bendix replacement, 700 Sportsman yamtz ATV Repair and Maintenance 1 11-16-2009 06:51 PM
bendix gunner789 ATV Repair and Maintenance 1 03-25-2009 09:09 PM
