09-05-2010, 10:42 PM
Member #6979
Best all-around tire??
Just wanting your opinions on whats the best snow, mud, trail after market tire and what ply. Thanks.
09-06-2010, 04:41 AM
Member #2920
If your upgrading go with at least a six (6) ply tire. Don't waste time on anything below that. As for all around tires go, Maxxis Bighorns, and Bighorn 2.0 are very solid all around tires. ITP makes the Terracross that is very nice as well. All three of these selections are highly rated.
Since I ride in VERY rocky terrain I went with an 8 ply tire from GBC Motorsports. The Grim Reaper performs well on everything I have encountered so far.
 - Polaris 3500 Winch
- Viking Hause Fairlead and Safety Thimble
- Elka Stage 1 Triple Rate Shocks with Rebound
- Front Lock n Ride Storage Box
- WES Lock and Ride Rear Touring Box
- Rotopax Front Storage Fuel Cells
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
09-06-2010, 05:03 AM
Member #4618
I can vouch for the BigHorns. They are great on all kinds of trail conditions, save "big mud". Haven't had them in snow & ice yet though. I will -- I spend a lot of time on the ice in the winter, always used chains before.
Mine are not the BigHorn II, I understand they a bit "lighter" in construction, not sure what they did to make them lighter, but my BigHorns are "tough as nails" and "bullet-proof".
2010 Sportsman 550 EFI
More mods to come.
09-06-2010, 06:07 PM
Member #1634
ITP XTR's are a good all round tire are radials so they ride great and last for a long time i got 1700 miles on mine and there just showing wear.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
09-06-2010, 06:13 PM
Member #4899
Tires seem to me to be site specific. Bighorns in the Texas mud are not going to be good here, and consequently Mudlites would be no good for rocky Colorado trail rides. You're going to need to analyze tires for your application and location. If you are looking for compromise then look no further than the stockers. My opinion - and you know what they say about opinions...
2010 Polaris 550 XP EPS
Polaris Lock n' Ride Front Cargo Box
Polaris Steel Rear Rack Extender
JamStraight Model 3157R LED Tail Lamps
If everyone is thinking alike, somebody is not thinking - Gen. George Patton
09-07-2010, 03:56 AM
Member #5629
If you are looking to upgrade your tires, you may ask and look around at what people in your area are using. Then decide which ones you want to try. Use others knowledge, just like here.
Con
09-08-2010, 05:52 PM
Member #2920
Thats some pretty fair comments. Look at your riding terrain and decide what's best for your area. I like mud, rocks and high speed trails so my reapers work well in those conditions.
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
09-08-2010, 06:38 PM
Member #3643
I'm using the TerraCross out here in New Mexico and they really seem to, "hook up" very nice out in the desert.
09-08-2010, 06:52 PM
Member #6015
Same here my two favorites are both Maxxis Big Horns and Zillas. Horns are the toughest with strong side walls and radial design made to grip the road and run smoother. Zillas shine in mud and are also good in snow as are the horns, but side walls are not as tough, Zilla's actually make a great trail tire you can tackle most any obstacle with. I would have no problem running either tire. If mud and deep snow are in your area Zillas are my choice and they are also very light. 27" Zillas are a awesome tire well balanced and smooth. I've had them over 80 MPH on my Brute so can vouch they are balanced. Maxxis makes good tires is my opinion. They are not like some of the other Chinese made tires. AKA ITP, They actually have strict quality control and it makes them better than the competition. Just my opinion.
2010 Sportsman 850XP EPS, 3500 Polaris winch synthetic cable and remote, front and rear brush guards, 5 HID lights, lock and ride rear box, Bighorn 26" tires on stock rims. Hand and thumb warmers.
Brute Force AMR 840 13.1-1, X4 Cams, Muzzy Pro, over-sized 39MM carbs, plus 1.5 mm over size valves, Big Kev performance full race port, JH machine clutch, programmable dynatek, Boss Noss wet nitrous system.
09-09-2010, 04:30 AM
Member #1414
ITP has a wheel plant in china, tires are still USA made. MAXXIS tires are made in TAIWAN.
2010 550XP EPS, 26" GBC SPARTACUS
09 850XP EPS
RT30 WARN WITH KFI MOUNT
best all around atv tire, best all around atv tires, best atv snow tires, best atv tire, best atv tires, best atv tires for trail riding, best atv trail tire, best atv trail tires, best polaris atv, best rated atv tires, best tires for polaris sportsman, best trail atv tire, best trail riding atv tires, best trail tire for atv, good all around atv tire, the best all around atv tire, top rated atv tire, top rated atv tires, what is the best atv tire, what is the best atv tire for trail riding
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
09 550 xp tire
mtatv |
ATV Wheels & Tires |
5 |
09-09-2010 12:44 PM |
tire help
huntingtheworld |
1 |
08-11-2010 04:52 PM |
Tire Help
deltadog |
4 |
07-08-2010 06:28 AM |
tire??
stickem |
ATV General Discussion |
0 |
04-18-2010 07:30 AM |
Tire help!!!!
jimthescrambler |
1 |
12-01-2009 05:36 PM |
