Originally Posted by jblack7880
I got your nut right here pal
LOL....I was just ribbin' a little jblack. I just couldn't get over the 45 mph thru the mud hole and the (probably not so innocent) muddie bystanders. If they're anything like my crew they instigated the whole thing. Welcome to the board!
Now about that motor, squirting a little oil in the cylinder is standard procedure when ya ain't got enough rings to make sufficient compression. If you ingested a little muddie water during the big splash it may have stuck 'em or could have done more. Try checking compression after it's warmed up good without any oil and then squirt a little oil in and check it. I'll bet a dollar to a donut you'll see the diff. You might want to consider new rings now to save a big headache later if you plan to keep it long.
Good Luck!...and don't let the "innocent bystanders" heckle you into hitting that mud hole any faster than 40 mph in the future.
