Old 09-07-2010, 05:19 PM
jinxie's Avatar
Member #7087
alternator output??
I am just new to the ATV world.
Ive purchased a 2004 Sportsman 600 with 800miles. The machine is very clean, but I bought it with the suspected front diff cage problem. I will post on that if I run into problems, but there seems to be enough info on the net regarding the fix.
My questions is to do with the alternator output. Since I plan on running in during the winter, I would like to run heated grips. Also, I am looking at a 2-up seat/trunk. It also comes with an option to hook up handlebar warmers.
What is the output on my alternator? Do I need to be concerned about the extra electrical load? Is there an upgrade if I do decide to run both sets of hand warmers?
Old 09-07-2010, 06:12 PM
Moose heated grips and thumb
Old 09-07-2010, 06:27 PM
Smoothbassman's Avatar
Member #2920
You should have more than enough power to run heated grips. Don't forget about the thumb too! I have a GPS, rally lights, camcorder, and a cell phone hooked up almost all the time with no issues on charging everything.
  • Polaris 3500 Winch
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
2010 polaris sportsman alternator
atv alternator output
do atv have alternators
do atv's have alternators
do atvs have alternators
does a sunl atv have an alternator
does an atv have an alternator
does polaris 600 have alternator
is there an alternator on polairs atv
is there an alternator on the polaris 300
polaris 700 alternator output
polaris 700 sportsman alternator
polaris alternators
polaris atv alternator
polaris sportsman 800 alternator
where is alternator located on polaris 400
where is the alternator in a polaris sportsman 450
where is the alternator located on a polaries atv
where is the alternator polaris 800cc
99 400 scrabmbler output shaft bluemonkey Polaris Scrambler 1 05-15-2010 08:05 PM
Exciter coil output 02 sportsman 600 lhilgardt759 ATV Repair and Maintenance 1 02-09-2010 11:30 PM
rear output shaft seal liv2plant Polaris Sportsman 2 02-04-2010 04:47 PM
High output motors sjcarp ATV General Discussion 3 09-03-2009 11:05 AM
High output sjcarp Polaris Scrambler 1 09-03-2009 07:17 AM
