09-07-2010, 07:57 PM
Member #7094
2008 Polaris sportsman 500 overheating
Can someone please help I have a sportsman 500 that everytime I ride it for more than say 20 Mins the light on the dash will start blinking and going crazy saying engine hot and I don't know why this is it is full of antifreeze and the fan always comes on as it should but it still says engine too hott can someone. Please help me with this problem???
09-07-2010, 10:11 PM
Member #5561
Welcome
Your radiator could be clogged with dirt, grass, or mud. Or the engine is running to lean, also check that the fan is running fast enough. These machines with cvt transmissions create alot of heat.
09-08-2010, 07:37 AM
Member #7094
The fan seems to run the same as always but I did go through alot of mud at one point I wasn't sure if this could be the problem or could it be that the water pump isn't pumping??
09-08-2010, 11:16 AM
Member #5561
Those pumps usually don't go out, but could be. I think the fan switch is on the radiator, so if the fan is running it's usually pumping like it should.
My friends Polaris fan went out and he would pour a bottle of water on it when it said hot. That cooled it right down.
09-08-2010, 02:45 PM
Member #4964
mine use to over heat do to clogged rad and fan! but check your rad for dirt and the little plate that goes over it.
09-10-2010, 02:03 PM
Member #6443
Check the plug going to the temp sender. It is on the left side of the engine, near the head. If you dont have good contact in the plug, the readout will say Hot and the fan will come on. You arent really overheating, just a sender malfunction. I expanded the male prongs on mine slightly and ziptied the plug together.
Have not had a problem since.
Hope this helps,
Jay
09-18-2010, 05:13 PM
Member #7364
Looks like I'm having same problem.....can you help me.
I'm a newby to this forum and a new Polaris owner.
I just bought a bran new 2010 Polaris Sportsman 500 HO carburated and its "running HOT"(machine as only 2km ans is still clean). The radiator fan is not turning "ON".
I have check the main fuse and its goog. Jump the radiator fan temperature sensor and the fan is still not turning (meaning that the temp sensor is good), I have check for fan motor connection and it also looks good. Does anybody have any idea on what to check next? I do not want to bring ATV back to dealer sinse the my dealer that I purchase from is about 2 1/2hr away. Please help.
thanks
Eric
2008 polaris 500 fan moatorrussle armstrong, 2008 polaris sporstman 500 overheating, 2008 polaris sportsman 500, 2008 polaris sportsman 500 hot check engine, 2008 polaris sportsman 500 overheating, 2008 polaris sportsman overheating forum, 2010 polaris sportsman 500 overheating, 500 overheating not radiator, over heated sportsman 500 engine, polaris 2008 sportsman 500 overheating, polaris 500 fan is constantly on, polaris 500 overheating, polaris 500 sporstman reading hot when it isn't, polaris 500 sportsman overheating, polaris sportsman 500 overheating, polaris sportsman 500 overheating problem, polaris sportsman 500 overheating problems, polaris sportsman overheating 500, polaris sportsman saying overheating 500 but its not hot, radiator fan will not turn off on 2008 polaris
