  #11 (permalink)
Old 02-12-2011, 10:10 PM
408Revo's Avatar
Member #11774
I am looking for a HID bulb kit
I forgot to mention that the reason why I want to know the bulb size is to replace the bulbs with a HID kit. I cant find a HID bulb that will fit my 2004 polaris 700 low beams. I asked earlier if the 880 fit the low beams and I was told only if it was a 880 bulb. So I do not know if it is a 880 bulb all I know is that the low beams bulb are model 81169. Sorry for any confusion. Thanks
  #12 (permalink)
Old 03-12-2011, 05:24 AM
AddictedUSAF's Avatar
Member #8858
I would like to know also, I am trying to help a buddy track down that same bulb size.
  #13 (permalink)
Old 03-12-2011, 05:43 AM
scott09's Avatar
Member #2160
i got the same type of bulbs in my 00 magnum, can't seem to find a replacement anywhere except the dealer, would love to go with hids if i knew which bulbs to buy.
2000 magnum 325 4x4 Hunter Green
2009 sportsman 500 efi x2 Red
2009 hyundai elantra touring Red
2000 Ford f150 Flare side 5.4l 4X4
  #14 (permalink)
Old 03-12-2011, 05:50 AM
mhollerich's Avatar
Member #9741
i know my buddies found some for his 08 ish 500 but i dont know where and its just the bulbs...will let ya know if i find out...dont know if newer is different
2009 sportsman xp 550
hand and thumb warmers
pure polaris mid windsheild
pure polaris front bursh guard
warn 3500 winch
  #15 (permalink)
Old 03-12-2011, 06:11 AM
Member #8858
Yeah 05 and up uses the 800 series bulbs. Its different for the 04 and down.
  #16 (permalink)
Old 04-07-2011, 08:07 AM
polarisisnthonda's Avatar
Member #13719
Here is a possible solution
This is a overpriced proprietary part from Polaris, but it is only the base of the bulb assembly that seems to be different, if you grab the bulb from the base where the brass part holds the glass bulb into the plastic base, give it a little wiggle back and forth and pull it out, it will come straight out and is not glued into it, and can be put back into place easily, only the brass part holds the bulb in place and the contacts rest in the plastic base easily, its a pretty basic assembly. Anyway once this is removed it looks like they took a standard 12v 35-40 watt auto bulb and bent the contacts into an L shape. I took apart a bulb from my 98 Chevy truck I had laying around, and they are the same bulb with the same contacts extending out of the bulb. the ones from the chevy just need to be bent into an L, except the chevy bulb was soldered onto the contacts unlike the Polaris one, I am on my way to the auto parts store to find the base bulb because I destroyed the bulb in the process of taking it apart. I didnt figure out it was soldered until I pulled too hard, I will repost if I find the right bulb and can make it work. Polaris robs you for a simple light bulb and forces such measures,
  #17 (permalink)
Old 08-30-2011, 01:43 AM
foreman26's Avatar
Member #17839
on the 2011 sportsman 850xp eps the bulbs are "ge 886" lots of places on the web to get them for about half the price as polaris
  #18 (permalink)
Old 08-30-2011, 05:29 AM
johnny_munyak's Avatar
Member #18153
Can anyone tell me what the model of the bulb is in the light by the handlebars on an 08' 800 sportsman? There must be an aftermarket bulb to cross over?
  #19 (permalink)
Old 08-30-2011, 10:23 AM
foreman26's Avatar
Member #17839
the newer sportsman's use the 50 watt "ge 886" in all three headlights
  #20 (permalink)
Old 08-30-2011, 11:17 AM
Member #18153
Hmmm....anyway to find out for certain the wattage? I'd hate to burn up the factory harness with a bulb that's too hot...
I can't figure out why the dims are the bumper lights and the high beams is the handlebar light??
2003 sportsman 600 replacement bulbs
2004 polaris sportsman 600 headlight bulb
81169 bulb
81169 bulb interchange
81169 bulb interchange#gsc.tab
81169 bulb polaris replacement
81169 light bulb
headlight bulb 81169
hobbs 81169
light bulb 81169
polaris 81169 bulb
polaris explorer low beams
polaris headlight bulb
polaris sportsman headlight bulb
sportsman 850 xp light bulb size
Replacement bulbs Bigriver ATV Visual & Body Modifications 7 07-17-2010 02:25 PM
what and where to get bulbs for my '01 Xplorer 400 ponchonutty ATV Repair and Maintenance 1 03-19-2010 06:45 PM
'05 Sportsman bulbs rotaxdave1 Polaris Sportsman 0 02-10-2010 02:09 PM
00 Sawtooth Bulbs cdakers ATV Repair and Maintenance 0 09-14-2009 12:57 PM
WTB 2006 Sportsman 800 headlight assemblies or gauge pod/headlight Angel of Death ATV Parts for Sale 1 09-06-2009 08:15 AM
