Gas Shut Off - Polaris ATV Forum
Old 09-29-2010, 07:13 PM
Wolfman's Avatar
Member #7598
Gas Shut Off
I have a 450 Sportsman, I don't ride it for a couple of weeks at a time. My question is do you shut the fuel off and then run the motor till it stops or do you just park it and start it up in a couple of weeks.
Old 09-29-2010, 09:28 PM
wayyyy better then turning the gas valve off and running till it dies (which i wouldnt do) is putting fuel stabilizer in the gas tank and running the motor for 5 mins or so so the fuel stabilizer gets all the way through the carb and a battery tender (read: no charger, there is a difference, if you dont know, just ask) on the battery....then you will be good to go. can leave the fuel valve open
Old 09-29-2010, 09:50 PM
yankyslayer's Avatar
Member #7739
dont forget to read the stabilizer instructions you need to add stabilizer every 3 months for 1 year the you have to dump the tank and replace the gas after that
2011 polaris spotrsman 90 gas shutoff position
atv fuel shut off valve
atv fuel shutoff
fuel shut off and on valve for 1998 polaris 400 sport
fuel shut off valve for 1998 polaris 400 sport
gas shut off polaris
how to shut off fuel on1998 polaris 400 sport atv
polaris 200 gas valve postion
polaris atv fuel shut off
polaris atv gas shutoff
polaris gas shut off valve
where is the fuel shutoff polaris 300 sportsman
Shut Off Problem PolarisRacer555 ATV Repair and Maintenance 6 07-09-2012 01:48 PM
Where is my gas shut off? 43-north Polaris Sportsman 5 08-19-2010 07:17 PM
Can I shut off the On-demand AWD on a 2009 Sportsman 500? buster634 Polaris Sportsman 20 06-17-2010 03:16 PM
1995 sportsman 300 4x4 nd gas shut off s/w rickhise ATV Repair and Maintenance 3 02-28-2010 12:19 PM
07 Sportsman 500EFI Hot Gas Shut Down?? sporthog ATV Repair and Maintenance 1 09-01-2009 01:40 PM
