No Electrical Power - Polaris ATV Forum
Old 10-07-2010, 02:09 PM
toolhunter05's Avatar
Member #7958
No Electrical Power
I have a 2007 Sportsman 500 EFI with under 100 hours of use. I am now having a random electrical problem. I have no power when I key up the quad. The kill switch is in run, turn the key on and most of the time nothing happens (Like a dead battery).
This all started with having random loss of power (meaning with the ignition on and kill switch in run, the fuel pump would kick on and speedo would light up then sundenly it would all shut off, Then kick back on, then off. Sometimes it would all power up and then you go to crank the starter and it would just click (like a dead battery). Now nothing will power up. The best description of this problem is like having a loose connection (but all are tight and do not have corrosion), hence sometimes getting some power to the ignition and sometimes nothing.
All the tests that I have run lead me back to the PDM (Power distribution module). I have a good battery (12.0V), I have 12v to the PDM, but only 4.5v going from the PDM to the ignition switch. Somethimes I will get a random surge of full power (12v) to the ignition, but then only a copuple of volts at the starter (so it wont crank), then it all looses power. I believe the problem to be in the PDM which is non-serviceable and very expensive. I am really hoping that its not that, since the quad is in exceptional shape with low hours, never abused.
I am still in the process of talking with my dealer about this issue, but i wanted to see if anyone has ever had a similar problem.
Any help would be greatly appreciated!
Old 10-07-2010, 02:33 PM
Old 10-07-2010, 04:38 PM
ZEUS's Avatar
Member #7484
Sounds like a Computer problem.
Polaris Sportsman 850 XP Camo 2010 - The Best
Honda Rancher 420 4x4 AT ES 2009 - The best MPG !!
Old 12-06-2010, 03:38 PM
dwb's Avatar
dwb dwb is offline
Member #9884
Yes I have the same problem with my 07 Sportsman 500 ..its the craziest thing I've ever heard of...let me know when u find the answer cause I walking to the deer stands
Old 12-30-2010, 12:51 PM
mackcat's Avatar
Member #10514
My 500 sportsman x2 was doing the same thing tried everything, finally figured out that it is in the Kill switch with the headlight switch and reverse override button. I started wiggling the red kill switch and power started flickering and eventually stayed on long enough to crank the engine. I have a new switch assembly ordered for $70.00 will let you know when i get it changed.
Old 01-01-2011, 04:03 PM
dwb's Avatar
dwb dwb is offline
Member #9884
Polaris ECM a problem but Cust Service reps are RUDE
My 07 Sportsman 500 has been at the dealer since Dec 7 finally they decided all my problems were a faulty ECM unit $400 bucks but they wil not start making these parts until Jan 10, 2011. Polaris just recalled 95,000 units from 06 and they don't even have one in the NATION!!!! The reps at the 800 customer service bascially said NOT MYPROBLEM and YOU DON'T HAVE ANY WHERE ELSE TO GO FOR HELP. I AM NOT A HAPPY camper and will continue to try and find someone at Polaris who cares. Polaris doesn't know anything about all these problems with the electrial system occording to their reps.
Old 01-01-2011, 04:26 PM
cookies's Avatar
Member #8052
i would call around to other dealers near you and see if they have one that will fit your machine.
Old 03-13-2011, 07:39 PM
jwiggin3021's Avatar
Member #12063
are you saying from 06 and up has another recall? i hope cuz my ecm s%!t the bed again! getting pretty sick of this ecm crap!
Old 06-17-2011, 03:17 PM
ronfjuarez's Avatar
Member #15910
You just described everything thats wrong with my 500efi 2007. Its not the kill switch assembly i just replaced it for 80.00. please tell us what you find out im just sick about mine just sitting in garage. mine has 51hours on it.
Old 06-18-2011, 05:11 AM
mackcat's Avatar
Member #10514
It Turned out mine was not the Kill switch, it was the Power Control Module (PCM) and it cost me $200.00 Dealer could not figure out what was wrong they were just replacing random parts, so i brought it home and fixed it myself.
05 polaris sportsman 700 losing power to ignition switch
2003 polaris trailblazer 400 no lights
2007 polaris 800 losses all power
2007 polaris sportsman 500 x2 efi key on lights on no run
2007 sportsman 450 loses power from the run off switch
2008 polaris sportsman 800 no power
99 polaris scrambler 500 has no power to ignition switch or to headlight what would cause this
polaris sportsman 500 no electrical power
polaris sportsman 500 no power
polaris trailblazer intermittent power
polaris x2 electrical problem
why does my 2010 550 polarus surge
electrical jmorgan2007 Polaris Trail Blazer 8 05-23-2016 09:29 AM
electrical glamishustler ATV Repair and Maintenance 7 02-13-2011 09:24 PM
Electrical problem banker ATV Repair and Maintenance 3 10-09-2010 03:53 PM
06 sportsman 500 efi no electrical power StrangeAK ATV Repair and Maintenance 2 09-09-2010 03:39 PM
Electrical issues carldonato ATV Repair and Maintenance 6 03-24-2010 06:10 AM
