I have a 2003 Sportsman 700 with a tore right rear cv boot. does anyone know if the entire axel (at the rear plunging joint) needs be removed from the casing prior to replacement? Also, on the 2003, is there a clip or pin holding this joint into the casing? it doesn't seem to pop off easily.
Just went thru same repair with spts. 500. Finally went with replacing cv axel complete assy.Boots were 40 $ (both).plus clips.I found the complete axel assy. on line for 130.00 delivered.You will fight the bands without proper tool.Found the axel at Super atv.com If you decide to replace boots only I found a pair of needle nose pliers with a notch in the end that worked good for the bands.But if iencounter the same repair I will not hesitate to replace entire axel assem.Good luck.
