Sportsman 500 no spark.This worked for me. - Polaris ATV Forum
Old 11-12-2010, 08:50 AM
incadave's Avatar
Member #4334
Sportsman 500 with no or very intermittent spark at first.
After many hours reading people's problems with this or the like i thought i should share with you all what worked for me.
This is on a farm vehicle that never see's any cover & is outside in all weather's.
At first i had come to the same conclusion as most of you about the coil or CDI unit but where do you start & the cost is horrendous.
By some miraculous happening i had a spark one day after it had sat in my garage for a week or more & i was able to start it on the pull as we had burnt the starter out but it was missing & back firing a lot.
All of a sudden it cleared & revved like a good un but what had i done?
Turned out i had turned the steering & then worked out it would misfire turned one way but ok if turned the other way.
Pulled the dash off & it worked ok until i put it back together & i was thinking maybe a wire in the loom breaking down?
Decided to disconnect the speedo from the wiring plug & hey presto it worked a treat & i did notice some water inside the speedo when it was turned upside down.Has to be worth a try if your quad is stuck in a dealers somewhere that they can't fix & only a 5min job to check & this one is rounding up sheep again as we speak.
Good luck.
Old 11-12-2010, 09:21 AM
phil's Avatar
Member #4618
Nice "catch" incadave. Nive to get something fixed simply isn't it? I think a LOT of problems are basic and simple (maybe not easy) fixes. Time consuming, for sure.
Glad you got it! You could have spent a lot of money for nothing.
3500 lb. Polaris HD Winch
VIPair Windshield
EPI HD Springs, Front & Rear
Cecco Frame Braces
Guru Bumpers, Front & Rear
Rhino Monster, Rear Box
Lowrance BAJA 540 GPS
SuperATV EZSteer 380
Various Mods for Ice-Fishing
Old 12-19-2011, 01:59 PM
woodzluva73's Avatar
Member #21493
Send a message via Yahoo to woodzluva73
i also have one of these fine machines with no spark ! new oem stator still no spark it sparks once and then doesnt again for twenty minutes or so ? This rig has been sitting outside for 2 years ..... im thinking junk !
Old 12-19-2011, 04:29 PM
unclekato's Avatar
Member #19204
These are fine machines but if you don't take care of them: example, leave them sit outside for 2yrs. DUH!!!!!!!!
2008 500 efi, oem front and rear bumpers rear rack 2500lb polaris winch
Old 12-20-2011, 12:57 PM
Member #21493
Im not the Idiot that left it outside ! mine sits in heated garage ! im the sucka that gets stucks fixing it ! DUH !
Old 12-20-2011, 04:21 PM
unclekato's Avatar
Member #19204
Explanations do help. Did you look to see if any critters got in and started chewin? Sounds like a wiring issue, something might be shorting.
Old 12-20-2011, 04:31 PM
justin95's Avatar
Member #21351
you should see if you cn pullstart it, i have a polaris sportsman 500 that starts good with pullstart but it doesnt with electric start. it turns over good but doesnt start... not sure whats wrong with it.
Old 12-21-2011, 12:52 PM
Member #21493
No critters found or chafed wires. The recoil housing was full of rusty muddy water when it arrived at the shop . That is all clean now with new stator and pick up coil . All my tests led me too that .
Old 12-21-2011, 04:39 PM
unclekato's Avatar
Member #19204
What exactly do you have. Is it a 500. Did you check the ignition coil(s). Or is the spark plug wire arcing .
Old 12-29-2011, 09:58 AM
Member #21493
Its a 2000 sportsman 500 . i havent gone any further with it because I needed a break and i primarily work on sleds and its that time .
1998 polaris sportsman 500 no spark
1999 polaris sportsman 500 no spark
1999polaris500hasnospark
2001 polaris sportsman 500 no spark
2003 polaris sportsman 500 no spark
2004 polaris 500 no spark
2004 polaris sportsman 500 no spark
polaris 400 sparking once and not sparking
polaris 500 sportsman no spark
polaris sportsman no spark
07 sportsman 450 with no spark 907Sportsman450rider ATV Repair and Maintenance 7 12-14-2010 08:18 AM
one spark sportsman midtown ATV Repair and Maintenance 2 11-19-2010 01:49 PM
sportsman 500 no spark pgray552000 ATV Repair and Maintenance 1 05-31-2010 08:38 PM
95 sportsman 400 4x4 w/ no spark fitz0698 ATV Repair and Maintenance 2 03-02-2010 05:00 PM
07 800 Sportsman No Spark clinictime Polaris Sportsman 0 01-19-2010 12:38 PM
