Old 12-12-2010, 01:27 PM
3inthedirt's Avatar
Member #9037
Clutch engagement ?
On the Trail Boss ('05), is it normal for the clutch to engage after probably 500 rpm increase from idle? Ours does not engage right away and I'm trying to figure out if I need to pull a shim out or get a different spring (like an EPI red).
Old 12-12-2010, 01:46 PM
mechanike's Avatar
Member #5749
being that the idle is over 500r's it should engage way over that. i have an Epi red and its perfect for this 250/Aaenexh/34mm carb.
Old 12-12-2010, 01:47 PM
Stealthepooty's Avatar
Member #6542
Is there a clutch cable adjustment? Sounds like maybe after 5 years, your clutch has worn down past the free play limit. Is there a way to adjust the clutch cable to give the cable some slack?
_______________________
2010 Polaris 850 XP, Warn XP-30 Winch, KFI Winch Mount, Steel Front & Rear Rack Extenders
My neighbor called the cops because I was playing Radar Love too loud.... they arrested him.
Old 12-12-2010, 01:56 PM
mechanike's Avatar
Member #5749
cvt system like the xp.
Old 12-12-2010, 02:03 PM
3inthedirt's Avatar
Member #9037
Do you know if the red spring is the same for all Polaris models? I have been researching and it seems that it is not model specific. The quad has so few hours that the belt may be dried out too. I need to pull the cover if it gets warm again and I have the time.
Old 12-12-2010, 02:40 PM
mechanike's Avatar
Member #5749
will fit the 250's 330's 500's 400's gen3's. polaris usually put a blue/green spring in(which i have a tool box drawer full of) about everyone stock.changing your secondary clutch position will give you alittle more R's.
2000 polaris 250 clutch postion at idle
adjusting clutch on polaris trail boss 250
clutch engagement on polaris sportsman
how do i adjust polaris atv clutch to engage quicker
how to adjust clutch polaris trail boss 250
how to adjust the clutch on a polaris 850
how to raise engagement on polaris
making clutch engage faster on polaris 330
polaris 850 xp slack
polaris atv clutch kits
polaris clutch does not engage
polaris sportsman 400 clutch engagement rpm
polaris sportsman 500 clutch engagement speed
polaris sportsman clutch position
polaris trail boss 250 rpm engagment
polaris trailblazer 250 clutch engagement
polaris trailblazer green spring
polaris trailblazer spring shim
polaris winch does not engage
sportman clutch engaging at idle
Rear Diff locker engagement issue katikyoo ATV Repair and Maintenance 3 07-31-2011 01:03 PM
having clutch problems wonder if its due to big tires or clutch wear HELP johnnypolaris500ho ATV Wheels & Tires 8 04-03-2011 07:17 PM
2004 Sportsman 500HO Questions on 4wheel drive engagement xracer ATV Repair and Maintenance 5 10-03-2010 10:23 AM
ATP 330 4 wheel drive engagement? NotQuik ATV Repair and Maintenance 1 08-18-2010 10:15 AM
HELP - Transmission engagement problem airzima ATV Repair and Maintenance 2 06-17-2010 02:25 PM
