Old 12-14-2010, 09:45 PM
61brown61's Avatar
Member #9852
Send a message via MSN to 61brown61
99 polaris 250 no start after rebuild
i just rebuilt the top end on this atv...new piston and rings and a used cylinder all stock ( not sure on cylinder but thats what the guy said) but anyways its seems like im not getting good compression.....it has spark and fuel but wont start....seems like it turns over really easy but it also has enough compression to blow out the exhaust.......the pistion went in semi easy ....didnt really have to compress the rings but it seemed tight when i pulled the rope without the head on.......
any ideas
Old 12-17-2010, 03:38 PM
mechanike's Avatar
Member #5749
get a compression guage $15 at autozone.if you can fit a feeler guage bigger than .005 its an overbore or wore.
Old 12-17-2010, 08:55 PM
Old 01-03-2011, 04:46 PM
jdereu's Avatar
Member #5980
agree with the compression text but if its coming out of the exhaust you should be fine. play with the card fuel line or even shoot it with some starting fluid
Old 02-08-2011, 01:51 PM
61brown61's Avatar
Member #9852
it still wont start...put a differnt jug on and it has 100psi compression....im thinking its a spark/carb issue...i can crank and crank and crank it and it fires like once every 5 mins with starting fluid but when i pull the plug it sparks good.....any ideas replaced coil under the hood by oil jug...it didnt have one...and new plug
250 trail blazer 99-all stock
03 polaris trailblazer 400 no start after rebuild
99 polaris 500 scrambler no compression
99 polaris trailblazer 250 upper end rebuild
help starting atv after rebuild
how to rebuild 2 stroke engine polaris 250 trailblazer
how to rebuild a polaris 250 engine
how to rebuild a polaris trailblazer 250 carb
polaris 250 carb rebuilding
polaris 250 engine rebuild
polaris 400 no start after engine rebuild
polaris atv won't start after rebuild
polaris trail blazer after topend rebuild it wont start
polaris trailblazer 250 good compression good spark good fuel
polaris trailblazer 250 turns over wont start
polaris trailblazer cranks but wont start
rebuilt atv engine and it still wont start
rebuilt polaris 250 wont start
trail blazer 250 cranks but wont start
what would cause low compression on a 03 polaris trailblazer 400
carb rebuild kid for 95 polaris taills64 Polaris Magnum 2 09-14-2010 08:08 AM
500 polaris wont start. need help please DJ harrison Polaris Sportsman 6 01-31-2010 07:53 PM
94 sportsman no start with carb rebuild ratherbflyn Polaris Sportsman 9 01-24-2010 10:18 AM
Polaris 330 Magnum will not start. tdgiff ATV Repair and Maintenance 1 11-30-2009 05:52 PM
'01 polaris 500 h.o. will not start mikes01500 ATV Repair and Maintenance 4 10-30-2009 07:42 AM
