Old 12-25-2010, 08:37 PM
61brown61's Avatar
Member #9852
Send a message via MSN to 61brown61
what cylinders interchange for 99
what cylinders interchange for a 99?
im guessing the cylinder is bored out too big..no compression and new stock piston
or what about a sleve? can i install them myself or do i need to take it to a machine shop?
250 trail blazer 99-all stock
Old 12-26-2010, 06:34 AM
4getful2's Avatar
Member #1234
Polaris has had that style of motor for many ,many years. You may want to disassemble it and check to see if maybe you didn't break one of the piston rings upon installation,or you may have purchased the incorrect piston and ring set for the bore--better off to let your machine shop do the ordering.
Sleeves can be had, but pricewise you might be better off getting a used jug off of e-bay.
Old 12-28-2010, 06:38 PM
61brown61's Avatar
Member #9852
so piston is 72mm and jug is 73.23mm what would be my best option...also if i just bought a sleve what would it be bored too? and does anyone have a hole jug theyd be willing to sell?
Old 12-28-2010, 07:11 PM
tt425's Avatar
Member #3687
I don't know of any 250 jugs. I have a 350 and a 400 jug for sale.
250 polaris piston to jug assembly how too
polaris 250 cylinder interchange
polaris 250 piston interchange
polaris 400 jug on 250
polaris 400l cylinder
polaris 400l cylinder for sale
polaris 400l cylinders interchange
master cylinder interchange ironhorse ATV Brakes & Suspension 4 01-18-2011 05:21 PM
part interchange dannyfogleman ATV Repair and Maintenance 0 10-14-2010 05:35 PM
Interchange manual justford ATV General Discussion 3 10-11-2010 02:33 PM
05 Clutch interchange BOBCHUK69 Polaris Scrambler 2 09-14-2009 05:39 PM
Aftermarket master cylinders indyguy ATV Repair and Maintenance 0 08-19-2009 06:24 PM
